help !!!!! emergency!!!!
Old Aug 29, 2006 | 01:13 PM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
Transmission: stock 700r4
i had my fan in my 86 iroc rigged up with a switch. now the fan went out. i bought a new one and a painless relay/harness from summit. when installing the wire that is supposed to go to the switch on the passenger head i found a plug instead of a switch. what tool do i need to remove the plug? it appears to be like an allen head but square. i can't find what i need. does an 86 stock 305 have an alternate location for thr fan switch? daily driver must drive it @ 5am. help!!!!!!!!
Old Aug 29, 2006 | 01:19 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Don't know the size but a lot of times the head from a 3/8" drive extension fits these plugs.
Old Aug 29, 2006 | 01:21 PM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
thanks. a 3/8 is too big and a 1/4 to small
Old Aug 29, 2006 | 01:24 PM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
when i got the car , everything was factory. it was working either off a switch/sensor or the ecm it' just that the switch isn't where it should be.
Old Aug 29, 2006 | 02:28 PM
PurpleHaze92's Avatar
Car: 1992 rs
Axle/Gears: ones that turn
Let me know if and how you get this fixed, I have the same prob. I havent gotten mine road ready yet so I dont drive it.
Old Aug 29, 2006 | 02:33 PM
Car: 1992 rs
Keep an eye on this thread
https://www.thirdgen.org/forums/cool...lant-temp.html
I think it will be good for both of us!
Old Aug 30, 2006 | 05:43 AM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
look on the front of your intake , purple haze. the sensor on the left is the coolant temp sensor. it sends signal to ecm and turns on fan. look through this link.http://www.chevythunder.com/fuel inj...lect. pg B.htm
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
smooth
Aug 18, 2015 06:34 PM
Bob88GTA
Aug 18, 2015 03:31 PM
jj4
Oct 9, 2000 01:31 PM
