help my car keeps overheating!
Old Sep 24, 2006 | 04:24 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i swapped my tpi iroc to a carb and i put in a new radiator and a new water pump i have a brand new radiator to thermostat hose. the car keeps overheating. to me it seems like there is not enough water flow. i have put plenty of antifreeze in and i used 50/50. the radiator is full and i even put some in the intake where the thermostat goes. today i took the car to the track for an f-body event. i didnt race but on the way back the car overheater. i say the gauge start going up and i shut it off but kept the ignition on so the fans would stay on. at one point it went up over 260 but it came down some. then i got it to cool out and headed back to the house and it did fine stayed right under 200 and then when i turned the car off the temp started going up. but when i take the cap off and run the engine it seems to cool down to a decent temperature. but on the way up there and on the way back it seemed fine for a long time then just all of a sudden the temp jumped up it was strange b/c it was running right around 190 the whole way back and then just all of a sudden it started jumping up really fast.
the thing that gets me is that the radiator hose from the radiator to the thermostat when you squeez it it doesnt feel like it has much water flowing through it but all the heater lines do. but the radiator hose does feel hot like it has had some flow through.
btw i forgot to mention today i didnt run a thermostat to try and keep the temp. down some. last night it was overheating too and i hoped this would help it out some.
if someone could give me some opinions/advice i would really appreciate it.
EDIT: i guess after thinking about it some more it seems like when i was going down the road at a good speed it was doing fine but when i pulled into the neighborhood and had to stop at the stop sign right after that is when it started acting up. and when i got home and turned the car off the temp started jumping up right after i turned it off.
Old Sep 24, 2006 | 04:33 PM
User Name:'s Avatar
I had that problem in my last camaro(I changed all that too).It was a flat lobe in the cam...I dont know how, but when I fixed it..no more overheating...
Old Sep 25, 2006 | 09:13 AM
Car: 88 IROC
well that doesnt make me feel very good.... but i doubt that is the problem anyone else?
Old Sep 25, 2006 | 09:37 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
have you replace the thermostat itself (inside the housing)? And the gasket?
edit: is your air dam (or air deflector) still under your car?? that can dramatically effect the cooling on our cars if it was torn off.
Old Sep 25, 2006 | 01:46 PM
Car: 88 IROC
yes airdam is on their and i changed the gasket and thermo...
Old Sep 25, 2006 | 09:56 PM
toogood002's Avatar
are your fans working correctly I changed the relays on my fans and when i drove it stop getting past 210 stayed at 210-190and that was mine just my 2 cents
Old Sep 27, 2006 | 01:21 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Turn your car on when cold and fill radiator as it warms up. Sounds like you have an air pocket in the system.
POZ
Old Sep 27, 2006 | 09:47 AM
Car: 88 IROC
the fans are working they come on with the ignition. also i think i fixed the problem it hasnt overheated since but we will see. i was also thinking an air pocket so i filled the radiator with the car running and it didnt help.
Old Sep 27, 2006 | 01:15 PM
toogood002's Avatar
what did you do to fix it if it wasnt the air pocket
Old Sep 28, 2006 | 08:46 PM
Car: 88 IROC
well.... when i finished up the car i didnt tighten the distributor all the way down, so i could adjust the timing. it wasnt loose at all but i did not tighten it all the way down and when i got down hard on the gas the distributor was moving and throwing off my timing. i think that is what fixed it. i still am running no thermostat and the temp is right around 180 so i hope when i put a thermostat in it the temp wont climb too high. but i think there was an air pocket i think that might have been some of the problem but i fixed that first and it was still overheating but it hasnt got over 200 degress on me since so i guess its alright.
Reddeath210
Oct 6, 2015 08:20 AM
mustangman65_79
Sep 1, 2015 03:51 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
