Steam for inside the cab.
Old Sep 30, 2006 | 01:16 PM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
Ok so when im driving my camaro, my windshield starts to fog up. At first it’s not to mad but after about 10 minutes of driving its starts to get bad. Now the air conditioning is off but when I stick my hand up where the defrost comes out it feels like it’s on. Also when I push the lever from cold to hot on the ac, steam starts pouring out really mad!
On a side note the ac is stuck on defrost. Don’t know why. Also when I come to a stop it seems to stop the steam form coming out and when I put my hand to the defrost I cant feel anything.
Old Sep 30, 2006 | 04:07 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Welcome to the wonderful world of replacing a heater core. You will never forget the first time. Find a place where the profanity will not bother any one and get a good manual. Have fun
Old Sep 30, 2006 | 04:34 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
yeah its most definately your heater core and its not that hard to do i did mine in my 83 in 15 mins there is only like 6 bolts that hold the cover on and one more thing the 1/4 drive ratchet is your friend !!
Old Sep 30, 2006 | 04:40 PM
Engine: 87 LG4 305
i thought it was that, i dont have time to replace it yet but i just blocked off the hoses and routed them into each other. will that work for now?
Old Oct 1, 2006 | 07:02 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
That will do it, until you need defrost.
15 mins?! ....................
Old Oct 2, 2006 | 10:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Stuck on defrost is a possible HVAC vacuum leak.
Old Oct 3, 2006 | 02:03 AM
Engine: 87 LG4 305
really, thanks man
Old Oct 3, 2006 | 06:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I agree with Stekman: Defrost is the default. Sounds like the typical vac leak to me. A will provide a ton of info.
JamesC
Old Oct 3, 2006 | 06:44 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Vac leak also, but the big problem is steam in the car, which is heater core. The hard plastic vac line are nitorious for braking. Usually it will be laying on the intake. BUT, if you have steam, and a oily film on your window, that is a heater core gone, with a vac leak. Replace hose with flexible tubing. Astro van are famous for that.
Old Oct 3, 2006 | 08:12 AM
JamesC's Avatar
I've experienced the steam from the core, but along with it came a fairly sizable leak which pooled in the pass side floor well.
JamesC
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
