Temp gauge problem
Old Nov 6, 2006 | 12:06 AM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
Temp gauge problem
I have a problem with my temp gauge. It does not move at all, and I dont want to rip cluster out if I dont have to. I replaced the temp sensor in the front of intake manifold but that didn't help. Also before gauge went out only the main fan would come on the secondary would never turn on EVER! The fan is still good because I jumped the wires and it still works but I still need gauge so I know where im at. Just wanted a little feed back before I break down and take it to a shop cause I would rather do repairs myself. Also if I upgraded to #24 injectors over stock #22 should i get a custom chip or are they ok to run stock. Have a adj maf sensor that I leaned out and seems to run fine but wondering if more power gains from injectors could be had with new chip.
Old Nov 6, 2006 | 02:08 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
The sender for the temp. gauge is in the drivers side head. The switch for the secondary fan should be in thr pass. side head. If you pull the wire off of the pass side sensor and ground it, the secondary fan will come on if all else is in working order.
Old Nov 6, 2006 | 02:58 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
thanks didnt know which was which Hayes manual sucks lol. I will change both sensors this weekend. Are they easier to get to than plugs because those are a pain especially for how big my arns are. But they still need to be done so ill do it just follow same 3 steps with plugs 1.patience 2. carefull 3. Beer
Any ideas on chip ppl?
Old Nov 11, 2006 | 10:11 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
I just replaced the temp sender and nothing changed. Maybe my gauge wire is broke, I still got some resistance in wire with ignition on i will check my gauge tomorrow and then run thru electrical system other than that im stumped
Old Nov 12, 2006 | 06:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Don't have to. Remove the black plastic bezel, the clear plastic gauges face, and the metal bezel to expose the guages. Remove two or three screws around the gauge and pull. Plug and play.
JamesC
Old Nov 12, 2006 | 10:57 AM
strnglvr's Avatar
Car: 2005 GTO,1969 Grand Prix, 1987 F/B
Engine: LS2,Pont400,Chevy305
Transmission: T56,Turbo400,T5
Axle/Gears: ?
gauges
check your fuses,.......? Pdk
Old Nov 12, 2006 | 11:19 AM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
yea i checked the fuse. that was the first thing i checked and its still good about to check gauge itself, then i think the wire might be grounded out
Old Nov 12, 2006 | 11:28 AM
strnglvr's Avatar
Axle/Gears: ?
gauges
anybody put a motor or trans in recently,if so, might have a wire pinched between trans and block, just think'n out loud,...Paul
Old Nov 12, 2006 | 01:08 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Changed temp sending unit to no avail. Removed plastic bezel and get this touched the temp gauge a wala it works. Never heard of that 1!
NOw neither of may fans work. The main fan would always worked normal but now doesnt The secondery would never work so i the it is the sensor. Dont know about the main 1 tho Im just thinking about fixing main fan and to run a switch for the secondary. any suggestions on this?
thanks for any input
Ghettobird52
Jul 5, 2024 11:18 PM
Bstrang6
Sep 8, 2015 04:29 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
