Coolant/Antifreeze???
Old Dec 11, 2006 | 02:07 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I just flushed my system and was told not to use dexron coolant which GM recommends. I heard it gives a nasty build up in the radiator with some kind of gunk or gum. Anyway I heard dexron blows, so what i want to know is what everyone is running coolant wise and what your mixture is. Funny thing is royal purple says you cant run their additive unless dexron has been through the system first. So anyway I am looking at buying either Peak Performance or THE YELLOW JUG.....(drum rolls)........PRESTONE. Says its good for ANY MAKE ANY MODEL? What shall I run and at what mixture?
Old Dec 13, 2006 | 01:03 AM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
50/50 prestone, cant go wrong
Old Dec 13, 2006 | 08:18 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Cool. Anybody know anything about Peak?
Old Dec 13, 2006 | 10:26 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Works fine.
Old Dec 14, 2006 | 01:10 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Same here, I use water that's when run through one of those purifying filters. If the car is old that's what I use.
Old Dec 22, 2006 | 04:55 PM
jcisthechamp05's Avatar
Car: 1987 IROC-Z
I'm third to agree with the prestone, I have never been dissapointed, I don't think you will be either.
Old Dec 22, 2006 | 05:40 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Prestone it is.
Stupid question: How much do I need?
Old Dec 22, 2006 | 06:26 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I believe the whole system is about 11 quarts.
Old Dec 22, 2006 | 07:18 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
My 96Z came with Dex-death from the factroy but I flushed that stuff after the expensive LT-1 factory water pump failed at 41,000 miles. Swithced all of my vehicles over to Peak products and have been satisfied so far...
After mixing anti-freeze for years trying to get the ratio as close to 50/50, I decided it was easier to purchase the pre-mixed jugs and get the job done.
Old Dec 22, 2006 | 07:22 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run 75% water, bottle of waterwetter and 25% of a house brand green Antifreeze (Valuecraft or whatever autozone sells) I have never had 1 cooling problem in both my cars
Old Dec 23, 2006 | 01:51 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
What if I put in Royal Purple http://www.royalpurple.com/prodsa/prpice.html
Should I do the 50/50....Prestone is Glycol right??
