LT1 head cooling alternatives
Old Mar 2, 2007 | 02:36 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
LT1 head coolant routing alternatives
I've read the article about the LT1 head swap and plan on doing this along with an LT1 intake. My question is about the coolant lines, I saw where the lines were run out the front of the head. My question is, Is this absolutely necessary or can you still drill the intake and run the coolant out of there. I know that my power steering pump is in the way and I don't want to move it unless it is the only way. Also with the four small coolant holes already present on the head, do they need to be crossed over if it's possible to run the coolant out of the intake instead of the front of the head or can I just block them off? Thanks.
midge54
Dec 27, 2019 04:14 PM
fbirdroller
Sep 2, 2015 10:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
sreZ28
Aug 14, 2015 07:48 PM
