new motor cooling?
Old Mar 16, 2007 | 05:18 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
new motor cooling?
im putting together a new 383..I have already install the thermostat and bolted down the water neck..
should I remove the thermo and stick a water hose in and fill the motor with water and then put the thermo back in? or just leave it and wait for the thermo to open and let water in from the radiator?
what should I do? any tips before firing this motor up?
Old Mar 16, 2007 | 05:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Just go ahead and fill it through the rad. The lower rad hose is on the fill side, and it'll get the coolant into the block quickly enough.
Old Mar 16, 2007 | 06:06 PM
so just leave it like I got...and dont fill the motor up? but the block is completely dry and empty......fill the raditor when I crank it the water pump will start to pull water from the radiator?
just out of curiosity? what is the circulation direction?
Old Mar 16, 2007 | 06:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The block will fill as you pour coolant into the rad. I promise.
Old Mar 16, 2007 | 06:29 PM
..ok will do..you promised!...LOL
hey..I also bypassed the heater valve..and took it out....I left the one hard line and ran it to the rad.....now, the other line goes to the fitting right by the water neck on the intake?
what about that piece of vaccum line that went to the valve? what do I do with that?
Last edited by Wishmaster's87IROC; Mar 16, 2007 at 06:32 PM. Reason: Automerged Doublepost
Old Mar 16, 2007 | 07:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can just plug the vacuum line.
This is on a TPI? You can route the heater hoses like they were on a non-A/C car.
Old Mar 16, 2007 | 07:05 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
is the motor broken in yet?? if not, how are you going to break it in?? drive it or park it??
if you are just going to drive it then happy driving.. if you are going to run it in the driveway for certain time, then i would suggest taking the thermostat out for that.. dont want that new motor broiling too hot..
Old Mar 16, 2007 | 08:07 PM
[QUOTE=Apeiron;3265994]You can just plug the vacuum line.
this is on my HSR....why does it show the hose going into the throttle body on both? I though it went on the fitting on the intake?
and as far as breaking it in...Im going to do it in the driveway...I cant drive it yet till I get the exhaust on and tag the car..
Old Mar 16, 2007 | 08:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The stock TPI circulates coolant through the throttle body to warm it. I doubt the HSR does that, so it'll go directly to the intake.
Don't worry about removing the thermostat.
The first time you run it, let it warm up to normal operating temperature with the radiator cap removed, and keep adding coolant as necessary. When it reaches normal operating temperature, put the cap on and add coolant to the recovery tank.
Old Mar 19, 2007 | 02:06 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
leave radiator cap off and fill when thermostat opens and cap.
fbirdroller
Sep 2, 2015 10:27 PM
TheExaminer
Aug 26, 2015 04:59 PM
Randomtask2
Aug 26, 2015 03:34 PM
TheExaminer
Aug 19, 2015 10:07 PM
Leggman1
Aug 6, 2015 04:15 AM
