cooling problems
Old Mar 24, 2007 | 11:21 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
cooling problems
hi I have a 91 z with a 5.0 tpi and the problem is when I drive it on the highway the temp goes to 220-250 but if I drive in town it stays at 150-200 it does not have any leakes that I can see and does have coolant in it,,,any thoughts
thanks
steve
Old Mar 25, 2007 | 04:59 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: cooling problems
You got an Air-Dam?
Big black plastic thing under radiator.
Old Mar 25, 2007 | 11:04 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
yes and it is in tact I looked it ove rtoday while changing oil
Old Mar 26, 2007 | 04:47 AM
VenomX-87's Avatar
maby the radiator is a bit blocked up and not cooling the water properly.
Old Mar 26, 2007 | 03:03 PM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
maybe you need a new water pump or your thermostat isn't opening up all the way to accomodate more coolant when the temp goes up
Old Mar 26, 2007 | 03:34 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the thermostat has not been removed/done away with has it ?
if the pump or the radiator were messed up then it would have cooling issues at all speeds/rpm's
good luck
Old Mar 26, 2007 | 05:07 PM
VenomX-87's Avatar
Thats a good point, IF youre RPM is high (2,000+) and you dont have a T/Stat to restrict the water flow youre water pump is pumping water through the radiator faster than it can cool it but in normal every day driving it wouldent realy effect it. If you don't have one I would throw a 180'F one in and see what happens.
Old Mar 28, 2007 | 05:29 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
ok so here goes I replaced thermostat then car ran 240 all time,,next did water pump same car ran 240 all time so I am thinking coolant temp sens. any thoughts????
and anyone know where it is on a 91 305 tpi??
thanks,,,,steve
Old Mar 29, 2007 | 06:14 PM
VenomX-87's Avatar
you can pick up an aftermarket temp guage and use it in place of the OEM guage (i dont trust any OEM guage) you should get a new temp sencer with it.
I don't know about the later 3rd gens but the older ones the sencer was in the drivers side head.
My OEM guage would read 260'F (head) when my aftermarket guage read 235'F (intake). you would think since the coolent has to go through the head to get to the intake it would be hotter in the intake than the head.
OEM guages ar ONLY a guide, that is why most OEM guages only say C or H not numbers coz they are not acurate enough to need them.
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
chazman
Aug 22, 2015 02:01 PM
