heater core removal
Old Apr 5, 2007 | 11:44 AM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
heater core removal
Need info of whats involved for heater core removal in a 82 z, or good book too follow by,--------looks like a pain, but havent attempted yet.
Old Apr 5, 2007 | 01:39 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Re: heater core removal
When I replaced the heater core in my '92 I had to take the entire dash and console out. I would definitely suggest getting the factory service manual for this job. Getting everything back in and aligned properly is a pain, but it can be done.
Old Apr 5, 2007 | 03:14 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
thanks, t.p.---my chilton book made it sound easy, it said on right hand side the heater unit comes apart in two pieces, and too remove right side too get too core. YEA RIGHT.-ITS ALL one piece as faR AS I CAN SEE.
Old Apr 5, 2007 | 03:34 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
I just took one out of my parts car a couple days ago (90 RS). It is two pieces, but there are about 8 screws to get it apart. Some of them are kind of hidden. Look carefully and you will find them and it will come out. Good luck.
Old Apr 5, 2007 | 03:39 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
The ones at the top are a b**** I used a 12in 1/4 extension and pull the front dash cover on the pass side and look closely thru the small gap and you can see the top ones. If the extension is long enough you can get them from there. Maybe a universal wouldn't hurt.
Old Apr 5, 2007 | 04:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
FYI:
https://www.thirdgen.org/forums/tech...e-82-86-a.html
JamesC
Old Apr 5, 2007 | 06:25 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
They arent too bad to remove. Some of the screws are a pain though. Aligning it back in took some adjustment when i did it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
