Upper Radiator Hose Bracket
Old Jun 18, 2007 | 07:33 AM
atomicskr's Avatar
I was looking over the car I just got and noticed that the upper radiator hose is rubbing on the belt. It is not actually touching but there is a notch on the underside so I assume it is hitting the belt when I go over bumps. It also looks like there is a spot for a brackt to bolt up on the air intake that would hold the hose off the belt. Am I right about this? If I am does anyone know where I could get one?
Old Jun 18, 2007 | 12:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Upper Radiator Hose Bracket
Mentioning year/motor is often helpful. The upper shroud for electric fans has a mounting provision for the hose. The hose itself has a ribbed, plastic protector. Note the pic:
https://www.thirdgen.org/forums/atta...orkel-fans.jpg
JamesC
Old Jun 18, 2007 | 12:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
where is your shroud ? the hose lays on the shroud and keeps it far far away from the moving parts of the engine
Old Jun 19, 2007 | 07:06 AM
atomicskr's Avatar
The engine is from a 1990. It's a 350 tpi but is installed in an '86 that came with a 305 (tbi I think it was). I have the upper radiator mount:
But that's not enough to hold it off the belt. What I'm looking for looks like it should bolt up here:
Here's how it looks all together. Is it possible that the hose is on backwards?
Old Jun 19, 2007 | 08:06 AM
JamesC's Avatar
I'd guess that the hose or the thermo housing is incorrect.
JamesC
Old Jun 19, 2007 | 07:46 PM
atomicskr's Avatar
any idea of the P/N for the hose or housing? or any idea what bolts into those holes on the bottom of the intake hose?
Old Nov 10, 2007 | 02:00 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Dunno if you ever found this out, but there is a little metal bracket that holds the hose that bolts in right there on the serpentine bracket.
Your hose doesn't look right regardless though. And the only source for the piece might as well be a junkyard with a 88+ V8. I think the trucks used the same passenger side bracket.
Old Nov 10, 2007 | 12:58 PM
atomicskr's Avatar
Yep I found it and got it all take care of!!! Thanks for the reply though
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
Stryker412
Sep 20, 2015 06:59 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
