What's the best refrigeration system flush?
Old Jun 29, 2007 | 07:12 PM
johnsonm's Avatar
Car: 86 Firebird
Engine: LG4 feedback controlled 350
Transmission: used to be T5 now T56
What's the best thing to flush your A/C system with?
I've heard rubbing alcohol, mineral spirits, liquor thinner, benzene, that stuff they sell in a can for $12 / quart called A/C flush… Anyone know the real answer?
Thanks!
Matt
Old Jun 30, 2007 | 03:14 AM
toms84ss's Avatar
Re: What's the best refrigeration system flush?
A/C flush in the can.
Old Jun 30, 2007 | 05:47 PM
1989CamaroLT4's Avatar
Car: 1989 Camaro RS
Engine: LT1 from '96 Corvette
Axle/Gears: 3.42 diff
I wouldn't put anything corrosive or flammable (benzene, etc.) through your lines. The liquid stuff in the bottle is best. You will need a flush gun and compressed air to use it. I rented a flush gun from AutoZone to do mine last year. Also, not sure if you know or not, but don't run any flush through a compressor or accumulator (it will saturate the dessicant bag). It's only for the lines, evaporator and condensor (if it's a serial flow condensor).
If you don't have air, I think AutoZone sells flush in an aerosol can, but I would be cautious of what sort of propellant is used in that can. It may be fine but just check to be sure before using it.
Old Jul 2, 2007 | 11:22 AM
johnsonm's Avatar
Car: 86 Firebird
Borrowed a flush gun and bought the dedicated A/C Flush.
Which by the way says "DANGER -- Extremely combustable Liquid!" right on the front.
Wouldn't most quick drying solvents be flamable...
Thanks for convincing me to get the real deal stuff though, works pretty well.
Old Jul 2, 2007 | 04:15 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
with household acs we use r11 flush:P then follow it with nitrogen!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
89 formula TPI
Oct 6, 2015 08:40 PM
bryan623
Sep 19, 2015 10:13 AM
84redta
Sep 19, 2015 09:58 AM
gta892000
Sep 16, 2015 12:40 AM
