Mysterious Disappearance?
Old Jul 21, 2007 | 12:19 AM
IROC444's Avatar
Car: 1990 IROC-Z
Engine: TPI 350
Axle/Gears: 3.23 posi
I have been noticing lately that my antifreeze is mysteriously disappearing. I just had a new radiator put in and noticed that it is not mixing with the oil. Any reason for this mysterious disappearance? I'll check the resevoir when it's hot and it will be full. However, when I check it when it's cold (about 5-8 hours after it's been driven), the resevoir is damn near empty. Am I just stupid, or is there a rational explanation for this? Looking for more help. Thanks
Old Jul 21, 2007 | 12:27 AM
spr250's Avatar
Car: Divorce stole it
Engine: Divorce stole it
Transmission: Divorce stole it
Axle/Gears: Divorce stole it
Re: Mysterious Disappearance?
did you check for loose hoses,puddles underneath, smell antifree burning. you possible might have had some air pockets, how long ago did you change the radiator. Everytime I've removed or replaced a radiator I've had the same thing.
Old Jul 21, 2007 | 12:44 AM
Duratys's Avatar
Car: 91GTA 89TTA
Engine: 305 3.8 Turbo
Transmission: MK6 2004r
Axle/Gears: G80 3.42s 3.27s
Sounds normal to me.
When the car is at normal operating temp the coolant expands and is diverted to the coolant tank. When it cools off its taken back into the radiator. There is a "cold" level and a "hot" level on the side of the tank. Make sure its at the appropriate level at either temps.
Tys
Just reread your post......you didnt say if you have been adding coolant to maintain the level. Since youve just changed the rad out for a new one Id agree with spr250 with trapped air in the system thats worked its way out. Top it up and keep an eye on it.
Old Jul 21, 2007 | 09:01 AM
IROC444's Avatar
Car: 1990 IROC-Z
Engine: TPI 350
I had the radiator replaced a couple days ago; there are no leaks coming from anywhere. Last night for example, the car's been sitting for about 7 hours and when I checked the level, the resevoir was damn near empty; below the Full Cold level. My hoses are fine but I do remember smelling anti-freeze when I stopped the car yesterday.
Old Jul 21, 2007 | 09:21 PM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
by any chance is your passanger side floor wet? if so you have a damaged heater core.
JJ
Old Jul 21, 2007 | 09:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not if you've got your coolant properly mixed and your radiator cap isn't shot.
Old Jul 21, 2007 | 09:39 PM
Duratys's Avatar
Car: 91GTA 89TTA
Originally Posted by Apeiron
Not if you're got your coolant properly mixed and your radiator cap isn't shot.
Being that his first post refered to having a new rad installed.....I took that as being done by a shop. Id be surprised if they didnt include a new rad cap.
I didnt know certain glycol mixtures expanded at diferent rates......Cooling effectiveness will be thou.
Old Jul 21, 2007 | 09:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Coolant under a 16 PSI cap won't boil until somewhere on the hot side of 260 F. It'll all stay in the cooling system until then, unless there's a leak.
Old Jul 21, 2007 | 10:30 PM
IROC444's Avatar
Car: 1990 IROC-Z
Engine: TPI 350
The level is good when hot, but cold I'm not sure. Yes I got a new cap, 16 PSI. Also, there is not leak anywhere the core is in good condition. This isn't effecting the engine temp so I'm not gonna worry too much about it. Thanks for the assist everyone.
Old Jul 21, 2007 | 11:50 PM
spr250's Avatar
Well if its not going into the oil or on the ground, Im guessing air pockets in the block that are working free. Its gotta go somewheres. More likely if you brought it to a shop they halfed***ed it, filled till stop going in at a steady rate and capped it off, seen it before-thats why I do my own repairs.
Old Jul 22, 2007 | 12:01 AM
Duratys's Avatar
Car: 91GTA 89TTA
The coolant level in the day tank rises long before engine temps reach 260F.
Old Jul 22, 2007 | 12:06 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You have a problem with your cooling system, then.
Old Jul 22, 2007 | 09:58 AM
Flesh&Blood's Avatar
Check your owners manual. Does it say ' Level should be at the "Full Cold" mark on the recovery tank when system is cold and at the "Full Hot" mark during engine operation.'? Mine does.
Old Jul 22, 2007 | 01:39 PM
IROC444's Avatar
Car: 1990 IROC-Z
Engine: TPI 350
I'm the 3rd owner of the car so I don't have the owner's manual for it.
Old Jul 22, 2007 | 01:56 PM
spr250's Avatar
The only thing I can think of is to, with the engine cold, fill the radiator and the overfill-to the cold line and go for a nice sunday drive and see all what changes. Another thing that I like to do, if the hoses arent reinforced is pump the lower hose to help work the air pockets out of the block and through the lines.
by the way, IROC444 are you Air Force or just live by a AFB. Im currently at Sheppard here in Wichita Falls, TX
Old Jul 22, 2007 | 04:08 PM
IROC444's Avatar
Car: 1990 IROC-Z
Engine: TPI 350
I'll have to wait for that drive since I gotta fix my hatch first. Yea, I'm actually at Tinker, been in the AF for about 7 years now.
Old Jul 23, 2007 | 07:22 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
you dont have to wait, just let it idle up to running temp. shouldnt take to long. any way i think i had a similar problem. I changed the temperature sending unit, and after i noticed that my overflow reservoir was pretty low and for a while it got lower and lower every day. now i just filled the resvoir up to cold full and have driven it a few times, it has stayed pretty consistant. just air i think.
Old Jul 23, 2007 | 07:58 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
After you've added coolant to proper levels, driven it, let it cool, re-filled and checked the coolant recovery tank, ... bring the engine to normal operational temp. Take the cap off of the coolant recovery tank while it's running. Check both the upper and lower radiator hoses to make sure their both hot. Check, look, do you see any air bubbles entering into the recovery tank while it's running?
diana227vegas
Jul 8, 2016 12:27 AM
Gordonr1973
Sep 29, 2015 11:59 AM
camarohelp
Sep 12, 2015 05:45 PM
SBlackfoot
Aug 13, 2002 07:20 PM
Xenodrgn
Jul 4, 2002 12:43 PM
