how hot will it run without a thermostat?
Old Jul 30, 2007 | 07:04 PM
super flash's Avatar
Car: 84 camaro iroc
someone school me here. i had an 89 rs and i removed the thermostat because i thought it was overheating . my gauge didnt work thas why. i had that car for 5 years and it didnt have an air damn either. i drove it on long trips. i would turn on the fan like when i stopped or after a long period of driving. it might have overheated a few times because i didnt turn the fan on. i would forget but it kept running without problems. just on time it ran outa water but i hadnt checked it for a while. oops.
Old Jul 30, 2007 | 07:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: how hot will it run without a thermostat?
It wouldn't run any hotter without a thermostat than it would with one.
Old Jul 30, 2007 | 07:13 PM
Car: 84 camaro iroc
ok, your patience is needed here, then why does it need one?
Old Jul 30, 2007 | 07:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The thermostat determines the minimum temperature of the engine, not the maximum.
Old Jul 30, 2007 | 08:04 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
A thermostats only purpose is to get the engine up to temperature asap, and keep it there. Without the stat, the engine will take much longer to warm up and likely wont ever reach normal operating temperature. I drove my 83 trans am 300 miles from OH to here in Michigan without a stat with 3.73 gears, and then drove it another month or so before I got around to changing it out. The temp never got to normal. About 150, maybe 160 was the highest. But I have mechanical fan and open grilles for radiator, so that helps.
but I also drove a 67 chevy truck with a 283 without a stat for over a year without a problem.
on non computer controlled engines the stat can be left out and the engine will usually be fine, but on cc engines, it will likely cause it to run in open loop mode which will reduce fuel economy, and little or no heat from heater.
As long as radiator is good, coolant is full, and the fan/s work correctly then the engine will not overheat without a stat.
Old Aug 2, 2007 | 04:41 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
If you are going to run with out a thermostat, use a restricter plate. The thermostat only determines minimum operating temps, it has nothing to do with max temps. My `75 GMC ran much hotter without a thermostat than with one. I use a 170 in my `88 Iroc. No need to worry about closed-loop operation. Closed loop happens when exhaust temp hits 600 degrees and engine temp is at about 160, you reach those temps after a mile or 2 of driving. If you use a 170 and up thermostat your heater will work fine. TPI Parts has AC Delco 170`s thermostats.
Old Aug 3, 2007 | 11:49 PM
TeknoMaeg's Avatar
You give alot of good information on this site... as far as I can see... but please read my long post in this thread.
https://www.thirdgen.org/forums/cool...stion-you.html
Old Aug 4, 2007 | 02:31 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What am I supposed to be seeing in there? You've got the wrong definition for convection, for one thing.
Old Aug 4, 2007 | 09:05 PM
firehawk71's Avatar
Car: 91 Z-28 Convertible
Engine: 305 TPI Bone Stock
Transmission: Auto 700R4 Stock
Axle/Gears: Posi with 2.73 Gear Ratio
My 2 cents,
Your car can run hot without a thermostat. Part of the job of a thermostat is to slow the water flow down so the radiator has time to cool the water. If you run witout the stat the water will move to fast through the radiator which will then cause you to run hotter. This is why they sell restrictor plates.
Also the Air Dam is a Must have to keep from overheating, I learned that the hard way on a 91 Z28
Old Aug 4, 2007 | 10:54 PM
TeknoMaeg's Avatar
I don't see how..
Originally Posted by wikipedia
Convection in the most general terms refers to the movement of currents within fluids (i.e. liquids, gases and rheids).
Convection is one of the major modes of Heat and mass transfer. In fluids, convective heat and mass transfer take place through both diffusion – the random Brownian motion of individual particles in the fluid – and by advection, in which matter or heat is transported by the larger-scale motion of currents in the fluid. In the context of heat and mass transfer, the term "convection" is used to refer to the sum of advective and diffusive transfer.[1]
A common use of the term convection relates to the special case in which the advected (carried) substance is heat. In this case, the heat itself often causes the fluid motion, while also being transported by it. In this case, the problem of heat transport (and related transport of other substances in the fluid due to it) may be more complicated.
As posted just before this.... with the fluid moving too fast though the system/engine it can slow the transfer of heat from the engine to the coolant and from the coolant and the radiator. Slower transfer means a hotter running engine.
theshackle
Mar 5, 2017 06:37 PM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
perZ
Aug 15, 2015 01:17 PM
