belt tension
Old Aug 5, 2007 | 11:39 AM
pearl83SS's Avatar
Car: 1983 Monte Carlo SS
Engine: 305 w/ cam
Transmission: TH350
Axle/Gears: 3.42 w/ auburn lsd +moser 28 spline
belt tension
how tight should ALL the belts be? i was always told as tight as u can make them, but wouldnt that add a lot more resistance to the motor? how much play should there be in the belts?
Old Aug 5, 2007 | 05:22 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: belt tension
You can actually buy a gauge that measures belt tension for cheap. The only way I have ever done it is to tighten the belt until it has about an inch or so of deflection. You don`t want to tighten them so much you damage any components. If your belts are squealing, you need to clean your pulleys and check/replace your belts.
Old Aug 5, 2007 | 08:30 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: belt tension
belts too tight can and will damage the unit they drive . the normal rule is 1/2 to 3/4 in. deflection at the longest span of the belt . after one week of operation , recheck and reset tension . just a normal rule of thumb . [ who is normal , not me . 68 yrs. old and still a gearhead ]
Old Aug 5, 2007 | 09:27 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Re: belt tension
Uncle Tom,I agree totally. I am only 57 and permanently disabled and bought my first 3rd gen last year. Old age and treachery will beat out youth and good looks. I am not sure about these serpentine systems yet, all I know is I have not had any problems with it yet.
Old Aug 5, 2007 | 10:09 PM
UNCLE TOM's Avatar
Re: belt tension
hey cool to get a reply , i think there are many of us old pharts that are messing with 3rd. gens . old hot rod stuff still works . any other old pharts out there ? [ this will blocked i am sure ] any way young people welcome to the gearhead syndrome ,"BEWARE " there is no cure . once a gearhead always a gearhead . I LOVE IT ....
Old Aug 5, 2007 | 10:18 PM
pearl83SS's Avatar
Engine: 305 w/ cam
Transmission: TH350
Re: belt tension
haha tom, if u want abnormal, u should meet my dad. aside from being a flat out nut, hes 63 and has two Ford Model-T's. one we finished restoring about 4 years ago. the other's body is sitting in the garage because we cant decide if we want to make a hot rod out of it or put it back to the way it should be. we restored the frame fully and its been waiting in the backyard under a tarp for two years because he keeps changing his mind. im not sure we r ever gonna finish that car haha
Old Aug 5, 2007 | 10:49 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: belt tension
rule of thumb is 1/4th in. of deflection per foot.
Old Aug 6, 2007 | 04:12 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Re: belt tension
Uncle Tom, have you figured out if the computer hurts or helps in general? They always seemed to me to be one more thing to go wrong. I hav`nt had any problems with the one on my `88 Iroc yet.
Old Aug 6, 2007 | 04:47 PM
UNCLE TOM's Avatar
Re: belt tension
i couldn't say , i have an 89rs lo3 eng and mild mods. . have not had any problems with mine in 3+ yrs. i have owned it . hope i don't . all problems unique to thirdgens that i have had i have been able resolve with this forum .
good luck .
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
anesthes
Sep 30, 2015 07:48 AM
kitt23
Sep 26, 2015 07:48 PM
