Problem and question
Old Aug 12, 2007 | 01:52 PM
Hal3246's Avatar
Car: 1986 P. Firebird T/A
Engine: Stock v8 305 TPI
Axle/Gears: N/A
Hey everyone, I'm going to start from the beginning.
When i first bought my T/A, it ran cool, roughly 180, sounds wierd.
The radiator then blew, got a hole, and for a while, due to the fact htat I don't have another vehicle, I only drove it to work and back which was close enough to get to before the engine got up to normal temp, this was durring the winter, or I would have walked, LOL.
For a lil while I had been driving it, I think approx. 1 month and then finally got the radiator replaced with an aluminum one, from Autozone $140.
Now, there is no leaks, nada, fan comes on when the dash temp gauge reads roughly 230 - 240 when parked and runs on times cool.
But today... the coolant in my resavoir ( I don't know how to spell that ) was boiling and my dash temp gauge read 220 or something, I don't quite remember. But it was odd.
But now that I do recall, it certainly hasn't ran as cool as it did before the old radiator cracked....
Any suggestions and any particular parts or mods I should do to try to bring it down, it must be running hot if I see coolant boiling in the resavoir
Thanks everyone.
Old Aug 12, 2007 | 05:24 PM
Hal3246's Avatar
Axle/Gears: N/A
Re: Problem and question
I'd hate to bump, but here I go, bump
Old Aug 12, 2007 | 11:16 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Just check and make sure your fans are kicking on when they are supposed to be. Even at 220 you are still alright temperature wise.
Old Aug 13, 2007 | 10:22 PM
Ford2transam's Avatar
Car: 1983 Trans Am ALL STOCK which is go
Engine: 305low
Axle/Gears: stock
I can't remember wich it is coolant sensor or tempature but sound like you gauge is reading wrong if it's boiling
Old Aug 15, 2007 | 09:35 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Sounds like your thermostat may have stuck in the closed position. Is your car a single or dual fan? You can replace the fan switch with one that comes on sooner than factory and you would also want to replace the thermostat so that they work together. You can get a 170 degree thermostat from TPI parts and a 185 on - 170 off fan switch from Summit or Jegs or your local parts store. Also, you should add 1 bottle of water wetter and use 30% anti freeze to 70 % distilled water. Make sure both of your air dams are in good working order. Check all your belts and hoses and radiator cap. Feel free to ask as many questions as you want to get your ride back on the road.
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Fronzizzle
Aug 9, 2015 01:15 PM
