a/c system issues...
Old Aug 16, 2007 | 01:13 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
i discharged my a/c and vaccuumed it down then put 24oz of 134a in it... it was blowing cool but i didnt have another can so i left it off till today when i could get another 12oz of refrigerant.
with the compressor running it was at 24lbs of pressure on the low side with two cans of refrigerant in. now 3 days later i checked it before i put the last can in and with the compressor running its up to 46lbs on the low side and with the compressor off it goes up to 150...
what could cause the pressure on the low side to double like that without putting in more refrigerant?
I dont have the money to have a mechanic look at it but i live in texas and my window motors are out so i need my a/c...
Old Aug 16, 2007 | 02:43 PM
gapimpin's Avatar
Engine: 383 LT1
Re: a/c system issues...
forgot to mention... compressor sounds kinda fugged too it makes a rattling noise. could that cause higher pressure readings?
Old Aug 16, 2007 | 09:20 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
I get some very strange sounds coming from the engine compartment when my air is turned on also. I can`t tell if it is coming from the compressor or the fan or what. My next project, upgrade the air, still original.
Old Aug 19, 2007 | 07:43 PM
gapimpin's Avatar
Engine: 383 LT1
I know 4th gen compressors are a different shape but could they be used in a 3rd gen? have a friend that wrecked his hawk and said i could have his if it would work for me...
Old Aug 19, 2007 | 08:26 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
if it's free take it, and then try to figure out if it fits, if doesn't sell it and buy new one for third gen
i am 70% sure that it is not going to fit tho
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
codeysabatini
Nov 10, 2015 04:07 PM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
gta892000
Sep 16, 2015 12:40 AM
