Heater box gasket
Old Oct 15, 2007 | 08:35 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Heater box gasket
I had to clean up and paint the heater box, and the old gasket was shot in a few places, along with there being rust under it I wanted to fix. So the old gasket was removed. Is a new gasket available or should I just use rtv?
Old Oct 15, 2007 | 12:29 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Heater box gasket
Use 3M strip cauk. It should be available from your local auto body supply store. Thats what the factory used on cars that didn't use a foam gasket.
Old Oct 15, 2007 | 03:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Dens71TA
Use 3M strip cauk.
JamesC
Old Oct 15, 2007 | 05:05 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
What would happen if you didnt use a gasket at all?
Old Oct 15, 2007 | 05:57 PM
JamesC's Avatar
It would leak, causing an already inefficient system to be more so.
JamesC
Old Oct 15, 2007 | 06:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
if you caulk it, it will be a beotch to get off later. they make a foam rubber weatherstripping for windows and doors, that is what i used and its great. I bought some about 3/4 wide and 3/8 thick. Still have some left
Last edited by //<86TA>\\; Oct 15, 2007 at 06:14 PM. Reason: aaaggghhh!!!! Automerged Doublepost
Old Oct 15, 2007 | 06:18 PM
JamesC's Avatar
Once every 20 years or so shouldn't be a problem .
JamesC
Old Oct 15, 2007 | 09:16 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
In reference to the no gasket, the couple spots where mine was completely flattened and not doing it's job, looks like water was dripping inside and rusting.
Thanks for the suggestions. I think for now I am just going to use no gasket. I want to take it off again in the spring to paint it nicer lol. The car is going into storage for the winter soon, and I mostly just need the firewall sealed as best I can from mice
HP52TA
Feb 3, 2018 10:51 PM
bubbaz28
Sep 18, 2015 02:09 PM
buckshot63
Sep 10, 2015 09:15 AM
hdis2002
Sep 8, 2015 02:52 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
