Waterpump or fan?
Old Jan 20, 2008 | 04:01 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Waterpump or fan?
My 84 camaro, 355 iron heads, stock style radiator, chrome half circle fan shroud, aluminum flex fan, stock waterpump and pulleys,thermostat or no thermostat it has an overheating problem, only on the freeways at speeds of 70+ mph or when sitting and idling. At freeway speeds (no od btw) it slowly overheats, but once it gets to 210*+ it starts creeping up in temp and doesn't come down, unless you shut it down and let it cool off.
i have no idea how old the waterpump is, but it doesn't leak, and the car doesn't overheat as long as your not sitting still or running it hard.
i've had a couple of ideas on how to get the temp down and stay down one of them being making a sheet metal fan shroud and a single 15 or 16" electric puller fan.
what would cool better a shroud that covers the entire back of the radiator with the fan in the center or, just mounting the fan on the radiator no shroud.
I really want to be able to bury the throttle on this thing or be bumper to bumper in cruise night traffic and have no overheating problems. I flushed the radiator and put in new 50/50 mix antrifreeze and that helped some but not enough for me so what should i try first?
Old Jan 20, 2008 | 04:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Waterpump or fan?
You can remove the rad cap, and start the car - when it runs warm enough (t-stat opens) you'll see the water flowing into the radiator - that will answer the water pump question.
Is the fan running? Plug 12v directly to it and see.
Is the fan relay functioning?
Is the fan switch in the pass head connected and working?
Do you have the air dam under the car installed? (30+ mph the vacuum created by air dam should cool car enough with no fan)
Old Jan 20, 2008 | 04:24 PM
stroker_SS's Avatar
Engine: 355
Don't have the electric fan. just an aluminum mechanical flex fan.
No air dam, but that will not solve the idle temp overheating problems.
Old Jan 20, 2008 | 05:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You've got a flex fan with a fixed spacer, no clutch?
Old Jan 20, 2008 | 05:22 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
get a nice dual electric setup. cant beat it!
Old Jan 20, 2008 | 06:55 PM
stroker_SS's Avatar
Engine: 355
Yep.
Old Jan 20, 2008 | 11:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could ditch the miserable fixed flex fan and use a decent stock 5 or 7 blade fan with a properly-working clutch and a full shroud, or you could swap in an electric fan setup.
Old Jan 20, 2008 | 11:56 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
The flex fan at 70 mph and above is useless with the RPMs the engine it turning, this is where you must have an air dam to reflect the air into the radiator.
I have seen flex fans that have have been run at high RPMs so much that they do not flex back to the position where they pull the most air.
Flex fans may look better but the stock fan is better. The best solution is electric fans.
Old Jan 21, 2008 | 06:07 AM
Car: 1992 RS
Engine: Carbed 350
And if you run an electric, there are controllers available from cheap ($30) to expensive ($100) that are easy to install. The more expensive ones come with options such as manual always on/off switches, adjustable temp settings, etc.
Old Jan 21, 2008 | 03:45 PM
stroker_SS's Avatar
Engine: 355
What do you guys think about this fan, i heard spal was one of the best.
Another option i heard about was the ford taurus fan. But i like this one better.
http://cgi.ebay.com/ebaymotors/16-SP...em300190947348
Old Jan 21, 2008 | 03:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'd be more inclined to find a stock or stock replacement setup so that you don't have to worry about figuring out your own mounting.
Old Jan 21, 2008 | 04:17 PM
AMigs87IROCz's Avatar
Car: 1987 Iroc-z
Engine: Swapped into a 350TPI
Transmission: T-56 Six Speed
Axle/Gears: Moser 12 Bolt 3:42 Gears
yea-do the electric fan set-up. It will be money well spent
Old Jan 21, 2008 | 05:47 PM
BigBadJohn's Avatar
Mechanical fan with no shroud = bad news
Mine seems like it never gets past the 125 degree area
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
