Upgrading to Dual Fans
Old Apr 16, 2008 | 09:53 PM
Fionnla's Avatar
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
I've had the 350 HO 330 HP installed for about 5 months now and today was the first day that I have driven it in real warm weather (78 degrees), and it would get up to 220-230 degrees in thick traffic but drop down to 190-200 on open road. The 85 Camaro has a single fan that comes on at 200 degrees and shuts off at 185 degrees with a 180 degree thermostat. It also has a new radiator. I'm thinking about going to the Universal Dual 11" fans that is a bolt on for 82-92 3rd Gen cars, and set that arrangement up the same as the single fan is now. Does anyone in the know think this will help solve the rise in temperature in traffic. Any advise would be appreciated.
The motor has a Carburetor with headers and 3" exhaust.
Old Apr 16, 2008 | 10:58 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Re: Upgrading to Dual Fans
what kind of water pump do you have.. if it isnt a high effiency it doesnt matter how much air you get through the radiator, its gonna get hot.. also check the cfm vs the amount of amps, sometimes you can get single fan that puts out a lot of cfm and draws lower amps
Old Apr 16, 2008 | 11:06 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Old Apr 17, 2008 | 05:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm running the 350 HO Deluxe with Hooker 2055's and a three-inch system. I converted to GM dual electrics. The following link details what I did so that both fans kick on with either the AC or head temp:
https://www.thirdgen.org/forums/cool...electrics.html
JamesC
Old Apr 17, 2008 | 06:09 AM
Fionnla's Avatar
Car: 85 Camaro S/C
Thanks for the info.
I do have a Edelbrock high flo reverse water pump.
I'm going to read over the Article in JamesC's reply.
The 220 degrees is probably ok now, but when it gets to ninty degrees, I think I'll have a problem. So, I want to get it squared away before then.
Thanks again.
Old Apr 18, 2008 | 10:13 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
Im Running 4th gen dual fans they were a snap to install. if you go to AutoZOne you can git a wiring kit for 30 bucks it takes all the headache out of installing switches and stuff I don't even have a switch. they come on when the cars hot and go off when the cars cold why do ppl put them on switches anyway?
Old Apr 18, 2008 | 11:51 AM
Fionnla's Avatar
Car: 85 Camaro S/C
Thanks. I ordered the dual fan setup from Eklers Camaro, supposed to be the same as the IrocZ 350 dual setup. I'm going to install the TCI wiring and switch kit for dual fans (200 on-185 off) Hope that solves the problem.
Hey James C, what degrees are you setting the intial timing? I got it set at 10 degrees advance, which is what is recommended from factory, the total degrees is about 32 advance. Maybe I could take it to about 36 degrees. What do you thank?
Old Apr 18, 2008 | 12:09 PM
JamesC's Avatar
IIRC, 32 is where I'm sitting and the car runs VERY well. You'll have to be the judge.
JamesC
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
scotrans am
Sep 5, 2015 04:26 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
