Temp. Guage stopped working?
Old Apr 26, 2008 | 03:56 PM
Iroc'nthe87's Avatar
Replace sensor? Doesnt read a temp whatsoever...
Old Apr 26, 2008 | 04:54 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Temp. Guage stopped working?
Did you chech fuse? try replacing the senors (1.) on the driives side head a lil green wire connected to a brass lil tab. 2. the coolant temp senor on the block on the passanger side
Old Apr 26, 2008 | 05:11 PM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Check the green wire..If it is loose your gauge wont read..Had that problem way back...Connection wasnt solid...reconnected and blamo! she worked
Old Apr 26, 2008 | 05:17 PM
Havnt checked the fuse, but the wire connection seemed solid. Ill have to check it again.
Old Apr 26, 2008 | 07:58 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
make sure you got voltage goin to it
Old Apr 26, 2008 | 08:08 PM
Shamble's Avatar
Car: IROCZ
Engine: LB9
Axle/Gears: posi
Another possibility you can assume is the temp needle is stuck. My temp gauge shoots passed 220 and gets stuck between the gauge and the cover. So I had to bend the gauge (this isn't visible when assembled)so the needle would just hit it and fall back down when I turnon my ignition. Just a thought, I apologize if this isn't your issue.
Ghettobird52
Jul 5, 2024 11:18 PM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
