Not starting over fan switch temp
Old May 20, 2008 | 01:11 PM
jreze8's Avatar
Car: 1991 Iroc Z28 Camaro
Engine: 5.7L V8 350CI
Transmission: Stock
Axle/Gears: Stock
1991 Camaro Z28
350ci 5.7L TPI
When my car would get over 220 it wouldn't start again till it got below 220. I replaced the stock fan switch with a 165 and now it only starts when it is below 165.
Can anybody help?
Old May 29, 2008 | 12:16 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: Not starting over fan switch temp
Does it crank over and not start, or does it not even crank over. Either way, it's not (or shouldn't be) effected by fan switch.
Old May 29, 2008 | 01:30 PM
Oscar's Avatar
This exact problem sounds familiar to me. I've had this many times. I believe my issue was as the engine got really hot, so did the starter. When I shut the car off and went to restart it, the starter would not kick. In other words, nothing happened when I turned the key. It would start again though after a while. I don't have that problem anymore though since my car never gets that hot now.
Old May 29, 2008 | 02:08 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Try new starter.
First, heat shield or wrap on starter.
Though should'nt have problem if starter good.
Could be heat soak on marginal starter.
Later
jreze8's Avatar
Transmission: Stock
Axle/Gears: Stock
It does not even crank... The fan comes on and all the gauges and such but the starter won't even kick...
Old May 29, 2008 | 02:27 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
these cars are so old, i wouldn't be surprised if someone wired up the fan relay along some circuit involving the starter.
Good idea if you get the time. Let the car cool. Find the wire going to the fan switch, cut it or swap in a new set hooked to a toggle switch. Turn the car on, if it starts turn it off, then flick the switch and try again. If the switch effects the starter, then have fun tracking down exactly how someone ghetto rigged your electrical system. Follow the starter wires until you find the culprit.
If it's heat soak, maybe the fact that it's following the fan switch is all in your head.
Old May 29, 2008 | 09:12 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
You need to determine if your getting power to the starter when it's not cooperating. Check for power at starter main power wire and the smaller wire (on the other terminal) while turning key to start. If there's power present, your starter is the problem.
Double check battery connections, ground wire connection to engine, and main power wire connection at starter.
I fought heat soaked starters for many years when my car was completely stock. Been thru lots of starters since I bought the car in 84. Abt 6 years ago I installed a gear reduction starter (CVS I think) when I replaced my 305 with a 383. It's never even hinted at struggling. Love that starter!
Old May 29, 2008 | 09:18 PM
jreze8's Avatar
Transmission: Stock
Axle/Gears: Stock
I will look into it and let you know... thanks for the help guys
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
TheExaminer
Aug 26, 2015 04:59 PM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
