Air conditioning problem (compressor...does it work?)
Old May 30, 2008 | 06:30 PM
Jammin'Trey's Avatar
Hey guys there is a very small amount of R-12 left in my system..So my compressors' magnetic clutch will not turn on. Is there any way to trick my pressure sensor to see if it works? Could I put a few psi of air in the system to see it the compressor turns on (like 10Psi?)
Thanks in advance guys.
Old May 30, 2008 | 10:39 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: Air conditioning problem (compressor...does it work?)
Introducing air into the system is a BAD IDEA. If you want to test it out go to the parts store and get a can on freeze 12 to put in it.
Old May 31, 2008 | 08:09 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
KOOL - ADE
"Is there any way to trick my pressure sensor to see if it works?"
Yes. Put 12 volts across the clutch.
Of course there is no need to run it more
than the half second it will take
to observe rotation.
Happy Racing !
|__|==(_)==|__|
— If people drove any slower
they’d be going backwards —
Old Jun 1, 2008 | 01:43 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Air is a bad idea. It can't condense and drives the pressure sky high. (Hence why vacuuming the system for 30-60 minutes is a GREAT idea when opening up the system or converting)
I wouldn't put any Freeze12 in there if you still have R-12 left. Particularly if you are going to be putting more R-12 in there. Freeze12 is 80% R134a which isn't compatible with the R-12 mineral oil currently in the system.
Old Jun 1, 2008 | 06:49 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Just unplug the plug in this pic and jump the two connectors inside it. As mentioned earlier, don't do it for more than a second or two.
Old Jun 2, 2008 | 05:12 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
do as titan said, jumper the connector, but dont do this to get the a/c system to work, its for testing only, its a low pressure switch to turn the compressor clutch off when the system is low, and running the system with low charge could mean the life of your compressor.
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
jackhammer
Aug 15, 2015 10:04 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
