Water Pump Question
Old Jun 7, 2008 | 10:50 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Water Pump Question
I searched but couldnt find my answer. Im currently doing a v8 swap and i need to know if a 1992 camaro z28 5.7 has a long or short style water pump?
Old Jun 7, 2008 | 11:45 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Re: Water Pump Question
reserse rotation from 88-92 f-body w/ serpentine belt setup.
Old Jun 8, 2008 | 01:52 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
I will be running V-belts so im gonna need a standard rotation water pump. I still need to know if its a long or short style water pump.
Old Jun 8, 2008 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check it out on Autozone, for example.
JamesC
Old Jun 8, 2008 | 10:00 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Autozone doesnt have it listed what it is. Someone has to know this. The reason i need to know is so i can get the right alternator and power steering bracket.
Old Jun 8, 2008 | 10:30 AM
JamesC's Avatar
You're correct: While the website would have provided you with the correct w/p, it wouldn't have provided the info you require.
JamesC
Old Jun 8, 2008 | 11:15 AM
thewolf's Avatar
Car: 1984 Pontiac Trans Am
Engine: LG4 305 V8
Axle/Gears: 10-bolt LSD
I would say the majority of small blocks have a long-style water pump. Blocks from the sixties and vettes used short-style pumps. If you were inclined to piece everything together, you could use whatever you want. Unless clearance is an issue, there isn't a compelling reason to use the less common short-style pump and associated hardware.
Old Jun 8, 2008 | 01:10 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
the simple answer is that it uses a long style water pump.
Old Jun 8, 2008 | 01:29 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Thank you lol.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
