Running hot, where to start?
Old Jun 10, 2008 | 07:12 PM
spray004's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: BTO 700R4
Axle/Gears: 4th gen 3.73
My 10.5:1 355 runs hot (200-210) only when the weather is warm and I get on it. I rode through the mountains a few weeks ago in mid 80's weather and it ran around 200 or unless I was cruising. Well now its in the 90s and I know its going to run hot. I'm running just water and water wetter. I've flushed the entire cooling system. Should I look at replacing the radiator first or look at an aluminum water pump. I'm running a 180 degree thermostat. Whenever the engine gets hot it cools back down (180-185) within 5 minutes.
Old Jun 10, 2008 | 07:25 PM
Nasphreak29's Avatar
Car: 87 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.27 BW
Re: Running hot, where to start?
If I remember correctly GM made their engines to run around 200-210.
Old Jun 10, 2008 | 07:29 PM
spray004's Avatar
Car: 1991 Camaro RS
Engine: 355
I'm not running EFI so 180-190 is my ideal temp.
Old Jun 10, 2008 | 09:15 PM
kerplunk318's Avatar
you running a mechanical fan? how fast were you moving when it was 200 or less? you have the air dam in front to deflect the air up into the radiator. 200 is a little high at any speeds over 40
Old Jun 10, 2008 | 09:26 PM
spray004's Avatar
Car: 1991 Camaro RS
Engine: 355
Electric fan. I was driving up the mountain and behind some traffic but I would say 30-60mph. The air dam is in good shape. I'm pointing to either the water pump or radiator. When its not 80+ degrees out it runs 170.
Old Jun 10, 2008 | 09:39 PM
my 406 with stock fans and radiator stays around 160-170 above 50 mph, i have a hiflow pump on it and 180 stat. probably wanna look into a nice water pump and get that fan turning on a little earlier
Old Jun 10, 2008 | 09:41 PM
spray004's Avatar
Car: 1991 Camaro RS
Engine: 355
The fan is hooked up to a switch so I always have it on.
Old Jun 10, 2008 | 09:47 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
thats not hot at all thats pretty normal. as long as its under 220 your fine
Old Jun 10, 2008 | 10:31 PM
i would put a highflow pump on there, are you running lean and or really advanced? 175-190 is ideal
Old Jun 11, 2008 | 02:35 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
How old is the radiator? It might be worth flushing it out, or replacing it. Also, FYI it's hard on the water pump to run 100% water. Antifreeze lubricates the bearings in it. I always put a gallon of antifreeze in, and the rest water.
Old Jun 11, 2008 | 07:37 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Nope. I thought it was pretty widely known, but i guess not. 195 F is the exact ideal temp for an engine, that is the temp where the combustion process is perfect.Also engine parts wear at a faster rate when colder than 195.
If it a car stays under 200* w/o struggling then you have no problems.
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
