high side fitting
Old Jul 6, 2008 | 01:06 AM
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
high side fitting
hey guys where did you guys get the fitting for the high side ..i do hvac for a living my manifold set reads r-12 and thats what im putting back in ..but my high side hose is to big for the liquid line fitting ...my suction line fitting will fit my hose just not my high side ????? is that a special GM adapter fitting
Old Jul 6, 2008 | 09:56 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: high side fitting
I just connected my gauges on the low side only. I was still able to vacuum it down and recharge the A/C.
If you find an adapter for the high side let me know.
Old Jul 8, 2008 | 08:08 PM
glock's Avatar
Car: 1989 gta
anyone????????????????????
Old Jul 8, 2008 | 09:58 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Prior to 87, both the high and low side ports were the same (7/16), which is the same as the hose ends on a standard gauge set. After 87, the low side stayed the same, but the high side became 3/8. You will need an adapter for your hose. Try your local parts stores, or online. I know mastercool sells an adapter set that will work for it.
Old Jul 8, 2008 | 11:47 PM
glock's Avatar
Car: 1989 gta
oh ok aleast i know the size now ill check some of my supply houses i should be able to find it thank you
Old Jul 9, 2008 | 12:55 PM
black89ws6's Avatar
I think the sizes I gave you was just for the threads on the ports. I believe the actual size of the ports themselves are 1/4" and 3/16" male flare. This page likely contains the adapter you need: http://www.mastercool.com/pages/charging_adapters.html
If i was to guess, I'd say you want the E 90337
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Fronzizzle
Aug 17, 2015 02:52 PM
TA8487
Aug 16, 2015 12:21 PM
timonator
Aug 11, 2015 09:56 PM
