Original compressor for a 87 GTA???
Old Jul 6, 2008 | 09:05 PM
fbody4me's Avatar
Car: 1980T/A,1987GTA,1989 GTA conv
I am trying to find out what is the correct a/c compressor for my 1987 GTA.It has a reman compressor on it now that needs replaced and I would like to put the original one back on it.I have seen several compressors with different model numbers and different styles of stickers (GM) that will fit but I am looking for the one that would have been on my car when in was new.Does anyone have a low mile all original 1987 GTA with the original compressor on it that would send me a picture?Any help would be greatly appreciated.
Old Jul 13, 2008 | 12:49 AM
fbody4me's Avatar
Re: Original compressor for a 87 GTA???
Come on,help a guy out!I am sure someone out there has an all original 1987 GTA.Does anyone know what model number the compressor should be?The model number is printed on the GM sticker.
Old Jul 13, 2008 | 10:11 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Well mine isn't low miliage but I think the a/c is original. It doesn't work and I don't think it has in a long time. I'll go look and see if it has a number on it.
Old Jul 13, 2008 | 10:21 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Okay mine reads.....
"Mfg by Harrison for General Motors Corp."
Model # 1131634
Code # 031071
Old Jul 13, 2008 | 10:37 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Old Jul 13, 2008 | 03:29 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
They are all R4's. The differences between one number and the next amounts to things like a v-belt clutch pulley or a serpenting belt clutch pulley, clocking of the coil terminals, and whether or not the pressure switch port is in the compressor casing itself, or in the compressor hose manifold.
Just go to the parts store you intend to purchase your compressor from, and they can get you the right compressor for the car. I'd call around/check the web for the best price, and given that the R4 is a tough compressor to rebuild right, I'd recommend considering a new one if it fits the budget.
Old Jul 14, 2008 | 12:18 AM
fbody4me's Avatar
Thanks for the picture 80schild.I do know that your compressor has the original style decal on it.I'm just not sure of the model number.I have seen about three or four different compressors on 87's with the old type decal and different model numbers.I wish you knew if it were original to your car.I had planned on watching Ebay for a NOS one to come up for sell because the new GM compressors I have seen look different than the original ones.They have a different decal on them and the front and back of the compressor looks different.I just would like to to be 100% certain of the model number.I know this sounds **** but I am trying to keep this GTA 100% stock.Its a very nice 2 owner car with 63,000 on it.I figure if I'm going to spend alot of money for a new compressor I might as well try to find the original one and not just one that will work.Hopefully someone else on here will confirm your model number as the original.Thanks again for you reply
Old Jul 14, 2008 | 07:05 AM
black89ws6's Avatar
Unless his was replaced with a used unit, it is original. Aftermarket, and GM compressor replacements had a different decal than that one. Reman units typically have no decal at all.
Chances are pretty good all the 87's you saw with different decal numbers were original, and correct for the application. I don't know the rhyme or reason to it. I've seen identical years, identically optioned chevy trucks, with R4 compressors with different numbers, too.
Good luck finding one with that original decal. Last month, I installed a brand new, right out of the AC-Delco box, R4 in a serpentine conversion on an 84 Camaro. New, not reman, AC-Delco, from GM. It did not have this type decal you are looking for.
What are the symptoms of your AC? Are you certain your compressor needs replaced?
Last edited by black89ws6; Jul 14, 2008 at 07:06 AM. Reason: not necessary to quote
Old Jul 14, 2008 | 10:29 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I think mine is original. Accroding to the previous owner the a/c hasn't worked in a long time, and it never was converted over to R134a. Even the hoses look pretty old. I understand what you mean about wanting to keep everything as stock as possible, mine needs alot of work and I'm trying to put as much back as original as I can. I'd like to get my a/c up and running, but so many other things needs fixing first. One thing I have noticed is that some cars have the compressor on the driver side (like mine), and some cars have the compressor on the passenger side. I wonder why they didn't build them all the same.
Old Jul 14, 2008 | 06:18 PM
black89ws6's Avatar
For the v8 engines, the compressor is on the driver's side for 87 and older cars, with a v-belt setup. 87 is the oddball year in that it has the same v-belt setup, but the water pump/alt belt is a 5 rib "serpentine-looking) belt.
Starting in 88, the v8 cars had a single, spring tensioned, serpentine accessory drive belt, just like all modern cars today. The serpentine mounting brackets put the compressor on the passenger side.
Old Jul 19, 2008 | 01:03 AM
fbody4me's Avatar
Thanks for the replys.Just wanted to let 80schild know that the compressor you have on your car is the right one.I have seen two very low mile 1987 GTA's and they both had the 634 compressor.Thanks for the picture
lee01
Apr 9, 2016 01:56 PM
gta90
Sep 15, 2015 04:00 PM
TheExaminer
Aug 25, 2015 07:34 PM
rh76camaro
Aug 15, 2015 12:48 PM
Street Lethal
Aug 13, 2015 08:28 PM
