A/C only blowing from defrost vents on dash pad
Old Jul 17, 2008 | 11:52 PM
Driver59's Avatar
Car: 1986 Pontiac Firebird
Engine: Custom built 350
I'm just trying to figure out why when I turn on my A/C that the air only comes out of vents in the top of my dash pad. It doesn't come out of any of the other adjustible vents in the dash itself or from the lower vents in the radio pod. Can someone please help? Thanks. By the way, I just have a regular '86 Firebird.
Old Jul 18, 2008 | 12:04 AM
theorio1025's Avatar
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
Re: A/C only blowing from defrost vents on dash pad
I beleive the systems are run by vacuum, as in other cars. Check the main vacuum line, and the vacuum control switch in the dash.
Old Jul 18, 2008 | 12:48 AM
Driver59's Avatar
Where in the dash is the vacuum control switch?
Old Jul 18, 2008 | 03:17 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
It is the AC and heater control itself. If you unbolt it you'll see the vacuum lines on the back of the controls.
Old Jul 18, 2008 | 05:40 AM
Driver59's Avatar
Thanks! I'll try that out and see what happens.
Old Jul 18, 2008 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Defrost is the default when a vac problem occurs. The piece is in the following pic is often the culprit:
https://www.thirdgen.org/forums/atta...duct010707.jpg
More info:
https://www.thirdgen.org/forums/inte...ht=control+vac
JamesC
Old Aug 3, 2008 | 01:07 PM
jaredc91's Avatar
https://www.thirdgen.org/forums/at...duct010707.jpg
What color is the wire that goes from the control to the engine?
I read that there should be a hard black plastic vacuum line but I don't see it or a spot for it on the control assy.
Old Aug 3, 2008 | 03:49 PM
the control line is attached to a vacuum canister by the braake booster on my car. the line is black up to the fire wall, and violet inside.
Old Nov 23, 2019 | 07:48 PM
97welter's Avatar
Car: 88 Camaro Iroc Z
Engine: 5.7 tpi
Do you have a set of the center dash vents for an 88 Iroc? How much shipped to 29406? Thanks
Old Nov 24, 2019 | 04:03 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Not sure who you're asking, but I have some good sets of those. get me your email address for pics and other info
Henry
Old Nov 24, 2019 | 04:48 PM
97welter's Avatar
Engine: 5.7 tpi
I’m not sure how my reply ended up in here yesterday, I was replying to someone selling dash parts. My email address is averywelter@gmail.com , thanks
Old Dec 1, 2019 | 05:18 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Did you get my pics OK? Just checking...
MantyZ28
Nov 8, 2015 06:54 PM
Stryker412
Sep 7, 2015 09:11 AM
Ian Irvine
Sep 4, 2015 08:08 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
