car still runs hot
Old Aug 28, 2008 | 08:39 PM
christopherrees's Avatar
car still runs hot
i have a 1986 z 28 in nv replaced hoses stat cap and coolant radiator still good but car still runs too hot any advice
Old Aug 29, 2008 | 04:52 PM
Re: car still runs hot
i ll pay someone in n las vegas area to hep me get right parts for my car so she can run cooler and stronger
Old Aug 29, 2008 | 05:30 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Describe "Too Hot"
Old Aug 29, 2008 | 08:08 PM
bfrd22's Avatar
Car: 1988 Trans Am GTA restoration proje
Engine: 5.7 TPI
Axle/Gears: 3:27
Not sure if the Camaro's are subject to the same issue but had the same problem. temp would drop a bit after sitting at idle for a while, then heat up soon as I got on the highway. turned out to be an airdam under the rad was pretty screwed up, replaced it and all is good.
Old Aug 29, 2008 | 10:25 PM
Kevin84Z28's Avatar
Yes, the air dam is a must,these are "bottom Feeders." But some people don't know that these cars in stock form run a bit hot. I've even seen where they say, "My car reached 220* it's running hot." 220* TO 230* is not running hot.
Old Aug 30, 2008 | 01:36 AM
GMLSX's Avatar
Car: 1998 Slow
Engine: Too Small
220 is operating temp...when it starts to near 240 is when you pull over and let it cycle...
have you checked your thermostat to see if its stuck closed and not cycling coolant?
is it the original radiator? after so long they become rusted and build up gunk, which can hinder the cooling effect in the coils...
also, are you using straight coolant or a diluted mixture of around 50/50 coolant to water?
just some ideas.
Old Aug 30, 2008 | 02:50 PM
Kevin84Z28's Avatar
I don't think he's listening.
Old Sep 1, 2008 | 02:33 PM
the radiator is stock 50/50 coolant new stat should i go ahead and throw in new radiator and if so what would be a good one and what about fan switch temp sensor etc
240 250 sometimes close to red
Last edited by christopherrees; Sep 1, 2008 at 02:37 PM. Reason: Automerged Doublepost
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
86Base
Aug 8, 2015 01:34 PM
