Need Pics of Air Dam for 90 IROC
Old Oct 21, 2008 | 05:32 PM
derekiroc's Avatar
If anyone has pictures of the 90 IROC Air Dam underneath shot to see if it has some type of air routing to radiator. I just got this car and they replaced some front end body parts and the temp runs around 220 to 235. My 82 has a plastic airdam that runs accross the bottom and never gets above 220 even when I run it hard. Thanks for the help.
Old Oct 21, 2008 | 08:17 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Need Pics of Air Dam for 90 IROC
air dam should be about the same, it's just a straight across piece of plastic on a slight angle, looks the same pretty much on all year maros for the most part, no special ducting or anything. There are air ducts in the grill that direct air into the radiator and to the air box. If you connect them it makes a decent ram air setup. Those temps sound about right, if the air dam is missing replace it.
Old Oct 21, 2008 | 08:47 PM
derekiroc's Avatar
Thanks for the reply. Ram Air hooked up, looks like missing lower radiator air dam. Does anyone have any pics?
Old Oct 21, 2008 | 09:06 PM
89RsPower!'s Avatar
Heres a pic of ghetto cruises car with the front bumper cover off, sure its a ta but you can clearly see the air dam, maro one looks the same. http://i57.photobucket.com/albums/g2...d/S6002036.jpg
Derick15
Sep 17, 2016 05:28 PM
PestilenceIV
Aug 20, 2015 02:33 AM
wruiz
Aug 13, 2015 09:07 PM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
