Stock air Baffle/shroud in front of radiator.
Old Dec 17, 2008 | 11:00 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
My car is an 86 and it does not have these pieces in front of the radiator. I believe they came on later years, but not sure when they actually started installing them.
It seems like a very good idea to help direct air through the radiator. Since they are OEM pieces I'd like to see if I could find some.
If anyone has these pieces on their car and wouldn't mind taking a few pics of them I'd appreciate it.
Also, if anyone know of the part numbers that would be great too.
I got the drawing off gmpartsdirect. They name the parts as follows:
1. Air baffle upper
2. Side w/o AC
4. Damper Assy. cover
5. Extension (would probably need 2)
6. Damper Assy. box
7. shim
8. Deflector
Thanks,
Attached Thumbnails Stock air Baffle/shroud in front of radiator.-air-baffle-3rd-gen.gif
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bryan623
Aug 10, 2015 11:33 AM
