found the leak, wtf is the name of the thing leaking
Car: 1986 IROC-Z28
this is directly underneath the throttle body on my tpi. the thing leaking is the one in the middle with arrows pointing to it.
to the left is the coolant temp sensor.
please help!
thanx guys
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: found the leak, wtf is the name of the thing leaking
Im pretty sure its called the cold start injector thermo-time switch.
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Car: 1986 IROC-Z28
Car: 1985 Z28
Def sound advice.
The first and last time I bought something at the dealer was a little over a month ago.
I went in to order the aluminum plenum extension off the corvettes, and the 3 screws to go with it. I had to do a double take when the bastard behind the parts desk quoted me $65. I told him to drop the 3 screws from the order as they were over $6 a piece! WTF?
And STILL, $40+ for a piece of aluminum about the size of my hand? That's a roadside robbery!
Car: FORMULA 350
Engine: ZZ4
WTF,,,,Lemme tell you WTF. Having been the so called bastard behind teh counter since 1983 I think I am qualified. I agree that 6 bux for a small screw is robbery. But the satisfaction of taking it in the brown is only realized when that over-priced screw fits perfectly. We(everyone who owns GM cars) should be thankful we don't really have to get it by driving a Chrysler. I know as currently being a Bastard behind the counter at a Chrysler dealer. Believe me, I am not going poor. Those cars are the biggest piles out there. BTW,,, by the end of March I will have moved to another GM dealer as parts manager. Maybe we can work out an on-line gig in the future.
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Thats because your being charge "list" price. "list" price is about 30-40% more of cost.
You might try summit, jegs, hawks, year one. Whatever other 3rd gen parts companies or parts dealers what ever you want to call them. They do have a lot of the sensors and stuff. Maybe even a TPI company.
Compare all the prices.
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
I'm currently at work, so I can't see the pic. But when I get home, I'll look at it, I may be able to get you a used one (I have a TPI setup sitting in my garage and have everything for it).
Is it just coming from the threads? Maybe removing it and re-installing it with some teflon tape will cure it if so. I've done that to every TPI car I've ever worked on, and never a leak after that.
yup, takes a pretty good sized deepwell socket. Dunno the size offhand though...
Car: 1986 IROC-Z28
Try a regular socket with a u-joint. Just be careful that it dosen't barely grab it.
If that dosen't work, you can take out the fitting above it and use a wrench.
