For those struggling with fans not working/fan control issues. A solution.
Old May 4, 2009 | 12:56 PM
87350IROC's Avatar
Car: 87' IROC
I've been fighting fan operation for some time now as well. ECM controlled fans, low temp fan switches, ect.
Here is a solution I am going with.
http://store.summitracing.com/partde...0&autoview=sku
The Dakota Digital PAC-2000. It can control 1, 2, or 1 dual speed fan. I have dual factory fans. With this device I can control both fans and adjust them to turn on and off at any useful temperature. You can even set it up to runs the fans for 30s-2min after the engine is shut down, if the temp is high enough. The device also has a digital temperature readout. Which will be nice for me so I can double check gauge and CTS readings. I plan to mount it in my ashtray so I can flip up the lid and see the temperature. I may also put a switch for each fan in their in case I want to override the system. The unit appears to be easily adjustable so you can adjust it for much higher temperatures when its time to go in for emissions testing.
You can feed the unit temperature data with either a Dakota Digital CTS or the stock CTS. If you use the stock CTS you will need to do a custom calibration. For $13 I decided to use a Dakota Digital CTS. I will mount it where the stock secondary fan switch used to be on the passenger side head. The best part is Dakota has 8 different temperature sensors. They have the normal 1/8, 3/8, 1/2 NPT and metric sensors to go in the block or you can get the temperature off of aftermarket temperature gauge signals. I went with the 1/2" NPT sensor since that is the hole size in my heads.
The sensors are here:
http://store.summitracing.com/egnsea...115+4294859904
I'm really excited to finally have control over my fans. I going to try my primary fan on-195 off-185 and secondary on-205 off-190. I am using a 180* thermostat. I plan to install it this week. Will keep you guys updated!
Old Aug 3, 2009 | 11:42 AM
87350IROC's Avatar
Car: 87' IROC
Re: For those struggling with fans not working/fan control issues. A solution.
I wanted to provide an update. I have been using this thing for a couple of months now and its great. For the first time in years I'm not constantly watching the temp gauge or flipping manual fan switches. Highly recommended for those fed up with trying to make the stock control system work.
Old Aug 7, 2009 | 10:49 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Cool. Where did you mount it?
Old Aug 7, 2009 | 11:40 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'll admit, that is a kick-ss controller but, at the $100 price tag, it isn't in everyones budget.
It is however, one of the best aftermarket controllers I have seen.
for the find, info and followup.
Old Aug 8, 2009 | 12:49 AM
87350IROC's Avatar
Car: 87' IROC
I mounted it under the passenger side dash to the outside of the heater box with velcro.
Old Aug 11, 2009 | 04:12 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
This may be right up my alley... My heads have cracked before because I was running without a fan for a while (bad wiring on the previous owners part) and I had a manual fan switch which was often neglected. Are you running dual fans or a single? I am running a single fan from a thunderbird SC..
Old Aug 11, 2009 | 04:26 PM
87350IROC's Avatar
Car: 87' IROC
I run the factory dual fans. The controller is setup to run a single fan, single dual speed fan, or dual fans. You could make it control more fans if you get creative. How big is that T-bird fan?
Old Aug 11, 2009 | 07:12 PM
one92rs's Avatar
Car: SOLD!!!!!
i run a flexalite controller for mine. i went with it since i can mount it in the engine compartment. and no extra relays are needed.
Old Aug 19, 2009 | 03:14 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
87350IROC,
This could be just what I'm after. A couple of questions if you don't mind...
Did you purchase an extra relay for the dual fans? If so what is the part#?
How easy was this to install? Can you scan the instructions for me to look at?
How do you change the on/off temps for the 2 fans?
Thanks,
Robert
Old Aug 19, 2009 | 05:53 PM
87350IROC's Avatar
Car: 87' IROC
http://static.summitracing.com/globa...k-pac-2000.pdf
There are the instructions.
I didn't order an extra relay or even used the relay that came with the kit. Since my car has dual fans stock I just used all the stock relays and wiring. All I had to do was tap into the signal wire for each fan's relay and connect it to the fan controller. Since I mounted mine near the ecm I just took the fan signal wire coming out of the ECM for the primary fan and spliced it to the first channel of the controller. I forget which ECM harness pin it was, but I can check. For the second fan I just spliced a wire from the secondary fan switch on the passenger side head into the second channel of the controller.
If you don't have factory dual fans, or just want to start from scratch it shouldn't be to hard but you will have to wire up relays. Check out the link above for wiring directions.
Here is the link for the second relay:
http://www.summitracing.com/parts/DAK-RLY-1/
It is the same relay that comes with the kit.
To adjust temperature you have to push a series of buttons on the controller. Check the instructions linked above. Its easy, and keeps the settings if you disconnect your battery.
Old Aug 27, 2009 | 07:41 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Many thanks, I think I'm just going to go with this solution myself.
Robert
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
scottmoyer
Sep 7, 2015 07:06 PM
dbrochard
Sep 7, 2015 09:41 AM
85Special
Sep 3, 2015 04:21 PM
