Waterpump Replace
Waterpump Replace
What size torx bits are needed to replace the water pump on a 1989 camaro 2.8? I want to replace my water pump but only want to buy the right ones I need and do you have to use a special tool to hold the timing cover in place to do it?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Waterpump Replace
while i'm not familiar with the v-6 engine , just buy a whole set . they are not very expensive , you can get a whole set for about 20bux or less . also a good addition to your toolbox . good luck .
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Hey Uncle Tom, excellent advice as always. The first time I worked on my Iroc none of my tools fit the fasteners on it so off to Walmart. Good tools for the price.
