Dunno what it is....
Old Sep 13, 2009 | 08:38 PM
Locruid's Avatar
OK quick background. I got a 87 Z28 (305 4bbl) I bought last year. Well this year the tranny blew so I replaced it. I also had to replace the flex plate and guess what I found? The original motor this isn't lol. I got it nailed down to a 80-85 305 (block numbers). Now heres my question....
On the thermostat housing there are 2 "sensors" One is just an electrical connection, the other has an electrical connection with a vacuum hose top and a spring in the core of it. The one with the vacuum broke in half on me so im curious as to what this actually is. Heck Id be VERY happy to find out what they BOTH do, but ill settle for replacing the broken one lol.
I can upload a picture of the broken off piece if needed.
The air intake cover says Turbo-Fire 175 hp but theres no telling if that was part of this motor or not :P
Old Sep 13, 2009 | 08:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Dunno what it is....
Originally Posted by Locruid
...the other has an electrical connection with a vacuum hose top and a spring in the core of it.
EFE valve, which can be seen between the exhaust manifold and the Y-pipe.
JamesC
Old Sep 13, 2009 | 09:05 PM
Locruid's Avatar
Wow, that was fast lol.
OK do I REALLY need it? I read a bit about it and what it does.
Old Sep 14, 2009 | 06:41 AM
JamesC's Avatar
No. Many people eliminate it when they switch to headers. My guess is that it's probably frozen open anyway.
JamesC
Old Sep 14, 2009 | 09:15 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The other one is the coolant temperature sensor for the ECM.
The EFE was mainly for emissions and cold driveability. You'll be lucky if it's stuck fully open.
Old Sep 14, 2009 | 10:13 PM
Locruid's Avatar
O ok, it runs pretty decent cold so ill ignore it. Thanx a ton everyone
grngryoutmyway
Oct 18, 2016 05:48 PM
Stryker412
Sep 7, 2015 09:11 AM
Timmys88Z
Car Audio
Aug 31, 2001 05:52 PM
87tpi420
Jul 9, 2001 10:50 AM
CamaroZ_85
Car Audio
Jun 5, 2001 02:17 PM
