View Poll Results: What is most likely the problem for my fan not turning on? and the fan works
Multiple Choice Poll. Voters: 5. You may not vote on this poll
my car overheats in 20 minutes
i have a 1991 camaro z28 5 speed 5.0 305 v8. my car is overheating fast. what makes my fan turn on? because it doesn't turn on. and i let the car heat up to 240. but i know for a fact that my fan does work when applied voltage. its an electric fan. i also just replaced the coolant, fan relay, thermostat housing and thermostat. and the the problem isn't my fuse. its fine. could it possibly be my coolant temp sensor. if it is how can i tell if its the problem?
Re: my car overheats in 20 minutes
db057
Aug 11, 2015 10:11 PM
