Clear coolant hoses?
Old Nov 5, 2009 | 08:21 AM
101btp's Avatar
Car: 86 Trans am
Engine: workin on a 383 for it!
http://www.killerglass.com/store/images/hemi2.jpg
I had seen this when I was looking over a few nitrous things on google, and was woundering is this stuff that will hold up on the drag track or is the "stuff for show only" I know that regular coolant hoses have the fibers weaved into them giving then a strong body but just wanted some opinions on here before doing any thing
Old Nov 5, 2009 | 01:23 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Re: Clear coolant hoses?
opinion #1: Don't use glass for coolant hoses that need to flex. Not even if it's only for a short section. If you want shiny show room material, use stainless braided hoses.
Old Nov 5, 2009 | 02:35 PM
101btp's Avatar
Car: 86 Trans am
O ok wasent sure if they auctially made a clear flex pipe that is other than glass?
Old Nov 19, 2009 | 01:46 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i was reading up on the site, basically just blown glass. They went to SEMA apparently. heres a 200 piece
Old Nov 19, 2009 | 08:01 AM
101btp's Avatar
Car: 86 Trans am
but do all the tubes have to be glass?
are their even clear tubes that can handle the heat/pressure?
Old Nov 19, 2009 | 08:05 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have seen clear hose used on different cars. Lowe's & Home Depot should have some in the plumbing dept. You will be limited to bends and size and I dont know how well it will hold up.
Nor do I know what purpose the hose is used, but you can buy it by the foot.
Old Nov 19, 2009 | 10:17 AM
101btp's Avatar
Car: 86 Trans am
Well one thing I know, well found out by trying, my next door neighbor his son had his old plowing truck over, bad coolant line *dam* so where to find some pipe? O why not try garden hose plenty extra laying around from other various projects? Not thinking about what temp is put onto it well it melted off but I think he was home because not a big deal was made of it
So I don't know if they put the heat rating on the hose?
I’m sure they might have some?
Old Nov 19, 2009 | 10:29 AM
haha beer bong hoses. The glass hose only needs to withstand 20psi i think. if its Pyrex, then its should work. I could stand on a upside-down Pyrex 9X12 baking pan and not break. I dont know if these tubes would stand to forces.
Old Nov 19, 2009 | 11:01 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Do a search on "Clear Vinyl Tubing". Im sure most is not for high temp use and could collaspe without a inner spring. You might try search under the brand Dayco.
I have seen corrugated clear/white pipe used in the food industry. It is flexable and can withstand higher temps. You would be a to see the liquid color through it.
Old Nov 19, 2009 | 04:43 PM
101btp's Avatar
Car: 86 Trans am
ya sounds better than the beer bong idea lol
Old Nov 19, 2009 | 09:17 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
you may think it's ok to use a glass fuel filter too since mr gasket sells them at auto zone and oreilys but they break, usually all over your motor. happened to me. glass has no place in the engine compartment. you may try to tighten the hose on it too much causing it to break or you may take it easy causing a loose connection.
Old Nov 20, 2009 | 08:06 AM
101btp's Avatar
Car: 86 Trans am
No I did not say in a single word that I had agreed to using glass
Any ya I know that it could break that's why I asked about using some sort of hi-temp clear pvc like tube!
And not to mention, vibration can crack it, temp makes the glass more brittle and winter would make me nervous or even under freezing conditions! along with if you are using a track you’ve never yet experienced their are un expected bumps and some could be a bad landing!
Old Dec 7, 2009 | 12:21 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Here's a link to clear radiator hose. http://www.rockymountainatvmc.com/pr...#vehicleSelect I don't think this co. makes it for our cars though.Sorry but that's the only clear radiator hose I've found.At least we know that it dose exist.
Old Dec 7, 2009 | 08:37 AM
101btp's Avatar
Car: 86 Trans am
I don't see why they would not make them because I know that in Foodservice they use some clear lines that take a lot of heat
Old Aug 14, 2019 | 06:47 PM
Micmouse13's Avatar
I know this is probably late but I had bought a glass radiator hose on ebay. Borosilicate glass! I tossed it in the air and let it hit the ground numerous time's. .. one secret about such glass is that a single impact at the right force will shatter it lol. Yep I broke it before I could use it! Cool **** though. . Look up borosilicate glass and you'll understand . Under pressure most things are MORE difficult to break unless a flaw during manufacturing exists. Remember the bouncing soda bottles lol. Mossy important DO YOUR HOMEWORK! ! Knowledge is POWER! ! GOOD DAY MY THIRD GEN BROTHER'S. ..
91 FIREBIRD FORMULA L98 5.7L 4" FLOW 3.73 IN THE TAIL UPGRADED T5 RACING TRANS=400+ OF INSANE 5 GEAR MESQUITO FOG FUN! LOL. ..
Logan Bryant
Apr 19, 2019 07:34 AM
CamaroIROC88350
Jul 21, 2010 02:03 PM
xlwhellraiser
Nov 16, 2004 10:10 PM
breathment
Dec 1, 2002 08:45 PM
Matty377
Jun 22, 2002 12:06 AM
