No cooling fan and coolant eruption
Old Dec 3, 2009 | 07:00 AM
markk's Avatar
Hey guys I have trouble. Fixing up an 86 Firebird 305 w/4bbl. First thing I noticed was coolant blowing back into the reservoir violently and coming through the cap.I then noticed the fan not running. I thought it was grtting too hot so to get by I ran a switched lead to the fan so it runs with the ignition on but it didn't fix the problem. I had the radiator flushed and replaced the cap. Don't know yet if I've fixed the coolant eruption yet but found out that my temp. light doesn't come on when I start the car like it should and I've changed the bulb. Anybody got an idea what is causing my fan not to work and do you think I've fixed my reservoir blow back. Thanks for your help and sorry for the long description.
Old Dec 3, 2009 | 07:20 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: No cooling fan and coolant eruption
I don't know about the fan problem but I did have a problem with the coolant blowing back out of the reservoir and turned out to be a stuck thermostat ( stuck in a closed position) that caused it to overheat.
Old Dec 4, 2009 | 11:58 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is A Watershow As A Bonus
Your bulb test circuit has an open.
Trace it from the BULB TEST contact in the ignition switch thru where it goes into the dash.
Does the coolant start gushing right away or does it have to warm up?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Dec 4, 2009 | 04:36 PM
markk's Avatar
Re: Car Is A Watershow As A Bonus
It has to heat up first. You're right about the watershow, I'm considering putting colored lights around it and adding a soundtrack...
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
