looking at getting a stewart water pump
Old Dec 9, 2009 | 09:45 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Going to get a stewart water pump to replace my electric pump. Just wondering what stage level to get and what rotation. I went to a electric pump back in 2004 and can't remember. I have a 88 iroc and my mods are in my sig. Thinking about a stage 3.
Old Dec 10, 2009 | 05:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: looking at getting a stewart water pump
Rotation will depend on the belt setup you plan. If you look at the tech article for removing the smog pump on a serp belt car, you'll see that the serp setups from factory used a reverse rotation water pump, all the others used a standard rotation including the v-belt cars and the 1/2 serp and 1/2 v-belt cars.
Old Jan 29, 2010 | 10:38 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
as i am looking at the car from the front the belt goes ccw. So then I should get a ccw pump, but what stage??
Old Jan 29, 2010 | 10:51 AM
Twin_Turbo's Avatar
Get the Stage II, the IIIs and IVs are for high rpm, the impellers are different and will not provide adequate flow on a hot day in traffic @ low rpm. Just because it's for a race car doesn't mean it's the best part for your application.
Old Jan 29, 2010 | 11:06 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
whats the part number for a stage 2 that will work in my 88
Old Jan 29, 2010 | 01:12 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
http://www.stewartcomponents.net/Mer...y_Code=ChevyS2
Old Jan 29, 2010 | 02:17 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
anyone have the polished version, and if you do, do they rust or chip off easily?
Old Jan 29, 2010 | 05:28 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
It's aluminum, it's just polished. Aluminum won't rust and there's no chrome plating to chip off
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
