temp send unit / fans
Old Jan 26, 2010 | 09:11 PM
timmy87iroc's Avatar
Car: 1986 Camaro Iroc-Z
Engine: 5.0
Transmission: AT
anyone have pics of temp sending unit loacation? also my cooling fans are not coming on at all, not even if i turn on the ac, any ideas? thermostat? fan relays? haven't had the car long so i haven't investigated to much yet.
Old Jan 26, 2010 | 09:13 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Re: temp send unit / fans
Temperature sensor between the 6th and 8th cylinders on the passenger side of the engine block. That SHOULD cure your problem.
Old Jan 27, 2010 | 06:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If the fan is not coming on with the a/c, I'd check the fan by applying 12v directly to it - the fans should run with a/c regardless of the temp of the coolant.
Old Jan 30, 2010 | 02:49 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
test with 12V directly to fan first to make sure its still good,
if it is good then your Fan switch would be on the Pass side between 6 and 8 as stated above
your temp sending unit is irrelevant because its sole purpose is to drive the temp gauge in the car, and that is located on driver side between 1 and 3
just wanted to clear up what everything was so if you go to a part store you end up with the right part and not something you dont need
im gonna bet its either a dead fan motor,wire short,Relay, or a bad ground and not the sensor seeing as it does not turn on with the AC at all
Old Jan 31, 2010 | 10:54 AM
Engine: 5.0
Transmission: AT
does it matter if the AC is charged?
Old Jan 31, 2010 | 11:26 AM
Caveman305's Avatar
Engine: L03, LB9
it shouldnt, i had a buddy that had a 305 TPI and he ripped his AC out all together and his fan still came on when it was suppose to, dont know if he had to ground a wire or not though
Old Jan 31, 2010 | 02:17 PM
Engine: 5.0
Transmission: AT
fan switch plug crumbled to pieces when i grabbed it, where can i get a new plug to wire in?
Old Jan 31, 2010 | 02:22 PM
Car: 1992 RS
Engine: Carbed 350
Stealership, or JY - maybe ebay
Old Jan 31, 2010 | 02:42 PM
Caveman305's Avatar
Engine: L03, LB9
Another member told me advaced auto carries the connector, dont know if u have to order it online or not
64goatman
Sep 9, 2015 01:09 PM
Glowsock
Sep 5, 2015 07:48 PM
85Special
Sep 3, 2015 04:21 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
