fan shrouds?
Old Apr 5, 2010 | 04:14 PM
chefman45887's Avatar
Car: 89 Camaro RS
Engine: 283 SBC
fan shrouds?
What companies if any make a fan shroud to where you could install a manual fan to my camaro ?
Old Apr 6, 2010 | 08:53 AM
Car: 89 Camaro RS
Engine: 283 SBC
Re: fan shrouds?
bump
Old Apr 6, 2010 | 09:57 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
Re: fan shrouds?
http://www.classicindustries.com/con...oductYearId=18
Not cheap but a good reproduction. Ebay is where I found mine. These things are getting harder and harder to find.
Old Apr 6, 2010 | 09:54 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: fan shrouds?
Best off is to hit your local parts yard/pick a part and grab a shroud/fan
set up off another cam/bird. Thats what I did to convert my L-69 from
that PIA electric fan to the mechanical fan set up.
Runs at least 30 degrees cooler............No more "is the fan running" and
260 degree plus temp issues !
Old Apr 6, 2010 | 11:13 PM
Car: 89 Camaro RS
Engine: 283 SBC
Re: fan shrouds?
i spent 3 weeks trying to find a shroud and fans , so im have purchased a dual fan setup(junkyard $50) and just ordered a universal adjustable fan switch$50. so i should be alright after this ty for your input.
Old Apr 17, 2010 | 10:33 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: fan shrouds?
Why not just run a lower temp switch, or reprogram?
Kind of silly going backwards.
-- Joe
Old Apr 17, 2010 | 11:56 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: fan shrouds?
Originally Posted by anesthes
Why not just run a lower temp switch, or reprogram? Kind of silly going backwards.-- Joe
Plain and simple.................
Some folks just don't have the time, skill, knowledge, etc etc. to mess with the factory electric fan set up let alone spending endless HOURS under the hood or on line here asking questions about fan switches, sensor replacement, etc. and STILL having overheating issues and continue scratching their heads with problems!
For most changing to a mechanical fan setup is simple and cheap
and solves the overheating problem..............
Not to mention some folks may find that their Cam/bird elec.
fan set up may have been cobbled/modified by a previous owner
so again a new sensor/chip etc. suggestion is worthless and out of the question.
Old Apr 18, 2010 | 09:09 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: fan shrouds?
I suppose.. It's just that, it's one of the more simple things on the car. Fairly straightforward. Power, ground, relay, and a 'switch'. The switch is either a thermalresistor on TBI applications, or run off the ECM on other (TPI normally) applications. TO make a TBI/non ECM car turn on lower, simply change the thermalresister switch in the head with a lower turn on unit. For a car with a computer controlled fan, it's a prom edit.
Probably give up 5+hp switching to a mechanical fan.
-- Joe
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
