temp keeps climbing
Old Apr 23, 2010 | 10:55 AM
87muscleman's Avatar
temp keeps climbing
i have a 87 trans am and during city driving or idle the temp stays nice and cool but driving at anything above 50 the temp slowly keeps climbing and seems like it wont stop! i have to keep my fan on even at highway speeds or else the temp goes throu the roof! its topped off on coolent the rad seems to have good flow and my therm seems to work fine! i was wondering if the rad is getting enough air flow? i notice on my trans am there is no direct air flow to the rad!! should i try cutting out some spots for air to get to the rad at speeds?
Old Apr 23, 2010 | 11:21 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: temp keeps climbing
If the car is overheating at highway speeds, my educated opinion would be that the AIR DAM under the front end of the car is MISSING.
Old Apr 23, 2010 | 12:06 PM
i am missing that! thank you very much!!! i will try getting that and see if it helps
Old Apr 23, 2010 | 12:54 PM
DJP87Z28's Avatar
That is the most important part of the cooling system on 3rd gen car.
Old Apr 23, 2010 | 01:13 PM
i checked everything else and that never crossed my mind!
Old Apr 24, 2010 | 09:22 AM
Where is a good place to get a air dam for my 87 Trans am???? for the next couple weeks im on a tight budget but i really need that part so i can drive my car with no worries!
Old Apr 24, 2010 | 10:48 AM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
A good place to find one.....and many of them would be at an Auto wreckers yard, and for cheap!
If you do go, KEEP the screws for the Air Dam from that yard car, just in case your screws are missing! It doesn't hurt to have extra!!!!!!
Old Apr 25, 2010 | 04:41 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
A junkyard could work. Most would probably be badly-bent, but you could probably find one or two decent-enough ones.
A GM dealer might still be able to get you a new one. Most types have been discontinued or have had part number changes, but some might still be available.
And if a dealer can't track any down, then here's a link to Hawk's. But with Hawk's, you never know... so if you order from them, don't order online assuming they have it just because they show it. Call them to confirm it--also to confirm whether it's new or used.
http://www.hawksthirdgenparts.com/airdams_1.aspx
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
