New Electric Fan Upgrade
Old May 4, 2010 | 10:53 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Hey guys Was wondering if any1 can shed some light on this for me. Im looking into getting a new electric fan for my car and wanted to see if anyone has any suggestions. My roommates said i should go to the junk yard and get a fan off a 2nd gen Ford Taurus but was wondering if anyone else would have any more recommendations or have ever done that switch.
Old May 5, 2010 | 03:18 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: New Electric Fan Upgrade
A friend of mine pulled got one and put it in a buick regal. It seemed to work well in that car but it was a V6. I dont know how well it will fir our radiator since it is a fan and shroud combination. I origionally had the single fan but upgraded to the dual fans found on later cars.
Old May 5, 2010 | 10:45 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Is your current fan going out, or are you having overheating problems? If not, then there's really no point in putting in a new fan. If it is, why not replace it with stock replacement?
Old May 8, 2010 | 04:46 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Currently the fan is fine but the engine itself has a mild build and tends to run a bit hot even with the fan. The temp is still within reason just i dont like it running that hot, also i Think i am just going to upgrade everything when i put in the new 383
Old May 8, 2010 | 07:39 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Those taurus fans are supposed to be damn good. A lot of guys have been putting them into full size chevy trucks running V-8's.
Old May 8, 2010 | 07:40 PM
chevysquid's Avatar
nother option is going with LS1 or LT1 fans.
Old May 8, 2010 | 09:44 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Is it Having problems that the fan Is just being overwhelmed by the engines heat or could it maybe be that the fan is turning on too late. If you got a lower coolant fan switch it could help keep your temperatures lower. If not then scratch this idea.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
scottmoyer
Sep 7, 2015 07:06 PM
