A/C Delete? Newb Q's
Old May 15, 2010 | 11:05 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Well pretty much heres the thing, I know its possible but I have some questions.
I might do a AC delete in the future (maybe later this year) but some things I am wondering about. First of all what would be needed? The A/c delete pulley & delete box? What else? Second is, I always wondered is if the Heater would go away with it?
I know it sounds dumb but I always wondered. My Camaro is a T-top car and with good weatherstripping and rust work I feel myself taking them off when I can when it is done. So leaving the A/C to be useless.
If anyone can provide any info that would be great!
Old May 16, 2010 | 09:28 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: A/C Delete? Newb Q's
the heat will still work.
A/c delete box and pulley is needed. If yours was 89 or older I have everything not sure about 92 though but the 89 and earlier used a different dash (only had center vents the rest were blocked off from the factory)and had pull cables for the vents instead of a vacuum setup behind the dash.
Old May 16, 2010 | 07:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I deleted A/C in my 1992 - as stated need the delete pulley and a A/C delete box. You can take the resistor pack off your existing heater box and replace into the new A/C delete box (alot of them don't come with the resistor pack). Heater will work fine. I didn't need the A/C delete pulley because I got rid of the serp pulley brackets at the same time, swapped alternator to pass side, and went to a 1/2 serp 1/2 v-belt setup.
Old May 18, 2010 | 11:29 AM
asfalto's Avatar
Car: '88 camaro iroc-z
Transmission: TH 700 R4
Axle/Gears: 2.77 Borg Warner Axel
i used the delete pulley only and left the original box (in italy it's so hard to find!).
everything works fine!
no problem with the heater!!
bye
Old May 20, 2010 | 03:36 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I have an AC delete box for sale, and the dash trim parts without the side AC vents.
Old May 20, 2010 | 03:58 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
How much you looking to get for the heater box?
Old May 20, 2010 | 04:25 PM
alloy's Avatar
Car: 87 IROC-Z28
$120 plus shipping.
https://www.thirdgen.org/forums/inte...elete-box.html
Old May 20, 2010 | 04:30 PM
Carlos773's Avatar
Sounds good, So my next question would be about the quality in some of the pulleys. I see on fleabay theres a mix of em and all ranging from $30 to $80 and Autozone carrys one for $30. Would you guys recommend those? What would be the problem with getting the more inexpensive ones? Breaking? Cheap quality?
Old May 20, 2010 | 08:37 PM
jstoltz's Avatar
They are fine use the autozone one I don't care for most of there stuff but the pulley was made the same as the gm piece.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
