Edelbrock Water Pump
Old May 26, 2010 | 01:50 PM
RiggsLW81's Avatar
Car: 1987 IROC-Z Camaro
Engine: 350 (5.7L)
Transmission: 700R4 (Auto)
I have an 87 Iroc..350/TPI...heavily modified...aluminum heads...vortech supercharger..
I want to upgrade my stock water pump to an Edelbrock high flow aluminum...
Which one (part #) do I need? I have searched summitracing and this site but there are a few choices.
Old May 26, 2010 | 02:51 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Edelbrock Water Pump
go with a stewart pump. They are probably the best one's for our cars
Old May 26, 2010 | 09:54 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
you will need a reverse rotation long style pump. Just look on edelbrocks site.
Old May 26, 2010 | 10:13 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
87 was still the vbelt/serp combo system, if you have or have switched to the 88+ serpentine system, you want water pump part number 8881
Old May 26, 2010 | 10:35 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
'87 was still the standard rotation V-belt system, and the Edelbrock pump is #8811.
Edit: here's the link: http://www.summitracing.com/parts/EDL-8811/
Old May 28, 2010 | 10:43 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I have an edelbrock water pump on my car and it's been fine. It's the high flow model and i'm running under drive pulleys.
Can I ask why you think you need a water pump?
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
