need to replace "plug" that fan relay plugs into
Old May 27, 2010 | 04:14 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I replaced my fan relay, and noticed that there was some arcing taking place. the plastic around the recepticle was melted. The fan works now, but I am concerned the relay will get fried again. Any input would be appreciated.
Old May 27, 2010 | 04:19 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Re: need to replace "plug" that fan relay plugs into
You may have had a bad relay to cause it to arc or a very loose connection which would cause arcing.
Did you take the old relay apart just for fun to see if there was an internal problem which would have caused the plastic to melt
Old May 27, 2010 | 04:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
They are available at the dealer - not cheap, and all the wires are grey, but available.
Old May 27, 2010 | 05:01 PM
I'll take it apart and check it out. Did you say; a bad relay could have been causing the arcing? Or did you mean a loose connection caused the relay to burn out? The melting was on the plug where the red wire goes.
Old May 27, 2010 | 08:02 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
check some parts places they carry the plug ends now like advanced auto and such
Old May 27, 2010 | 09:02 PM
irock88's Avatar
sometimes relays do go internally thats why I said for you to open it up and see if there was any internal damage to it ex. worn out contacts.
As well a loose connection will definitley cause arcing and melting of the plastic plug. Depending on the damage on the plug you may want to replace it as previously mentioned by camaronewbie
Old May 28, 2010 | 12:32 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
mine is like this as well, swapped relays and have had no problems since. These things get warm, especially if the car is running hot and the fans are on constantly. I like to check these relays periodically because mine decided to go south one day and at freeway speeds I was fine, but as soon as I got off the freeway, it got hot, real hot.
Old May 28, 2010 | 11:40 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I got one from www.tpiparts.net
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
92projectcamaro
Aug 6, 2015 01:20 PM
