coolant problem
Old Jun 1, 2010 | 02:27 PM
87irocz2887's Avatar
coolant problem
Let my 87 305 tpi run in the driveway the other night and it got up to about 180 degrees. I noticed that the coolant expansion tank on under the hood was clean full of antifreeze. I shut the car off and after a few minutes it went down. could this be a bad thermostat or a head being junk? also the electric fans are on constantly.
Old Jun 1, 2010 | 02:41 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Re: coolant problem
When the car is running the coolant expands and when the car sits it contracts and pulls coolant from the recovery tank. That's why there is a hot and cold fill line
Old Jun 1, 2010 | 02:43 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: coolant problem
I agree. Seeing it rise when hot is normal. If it's all the way to the top of the lid and it's clean (no oil... etc) sounds like you overfilled it.
Old Jun 1, 2010 | 07:39 PM
Re: coolant problem
would it matter if the tank was completely empty when the engine was cold?
Old Jun 1, 2010 | 07:54 PM
Twin_Turbo's Avatar
Re: coolant problem
not if it was well below the full hot mark when running. If it was at the full hot it should not come below the cold mark. If it does, you're loosing coolant somewhere.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
GTAman
Sep 21, 2015 09:57 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
