water pump clockwise or counterclockwise?
Old Jul 3, 2010 | 12:23 AM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
I have a 400sbc and its time for a new water pump, I'm trying to figure out if I need a cw or ccw pump. It has a v-belt drive so I am assuming that it is a cw pump but I just want to make sure.
If somebody could explain to me why the serpentine and v-belt is different that would be cool too. Thanks for the help.
Old Jul 3, 2010 | 09:33 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: water pump clockwise or counterclockwise?
v-belt is CW rotation-there are two styles of CW rotation
"long"style orignal chevy water pumps:1969-75 and
1976-87,IIRC the only difference is the position of the
bracket lug on the top.The reason rotation is important
is because the impeller blades are curved and will pump
poorly if rotated in the wrong direction.Also the hub bolt
pattern is different between the two rotations
Old Jul 3, 2010 | 11:51 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
The way the serp belt is routed, when it wraps the water pump it wraps it backwards - that's why
Old Jul 3, 2010 | 12:58 PM
Car: 1991 RS Camaro
Alrighty guys thanks that cleared it up for me.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
