Should I replace the rad
Old Jul 3, 2010 | 07:29 AM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
So I'm putting a 383 stroker in my car. I have the stock rad in it still, with the 350 in it I had no problem being cool it would run like 170-180. So my question is should I get a new stock replacement or aftermarket replacement. Maybe even just get mine flushed before it runs anything that might be in it into my new motor.
Thanks Tom
Old Jul 3, 2010 | 03:04 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Should I replace the rad
I would rinse it out and reuse it assuming it still looks solid.
Old Jul 4, 2010 | 06:58 AM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Yes it looks good no leaks. I will also be running a seperate trans cooler in front of the rad. Do I need to put brass plugs in the rad where the trans lines went into. Also what kind paint would I use to repaint the rad.
Thanks tom
Old Jul 4, 2010 | 01:57 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
the stock one is fine
91 rally sport
22
Apr 5, 2016 05:06 PM
Wade787b
Sep 29, 2015 01:15 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
