not your typical cooling question
Old Jul 5, 2010 | 01:15 PM
King NothingSS's Avatar
Car: 2001 Camaro SS
Engine: no engine yet :)
Transmission: T-56 with z06 drive gears
Axle/Gears: most likely 12 bolt or 9" with 3.91
i don't have a overheating problem . . . is it normal for my temp to be at 100 degress? even while i bang gears and drive it hard? i'm used to my 2000 camaro and the temp gauge staying at 208 the entire time regardless of driving habit. any input is appreciated
Old Jul 5, 2010 | 04:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: not your typical cooling question
Either your sender is bad (driver side head between #1 & #3 spark plug), or your guage is bad.
Old Jul 5, 2010 | 04:58 PM
Twin_Turbo's Avatar
Or it's in *C
Old Jul 5, 2010 | 05:29 PM
Car: 2001 Camaro SS
guage works as far as i can tell cause when i drove it home from the seller's place on saturday in traffic it was gettin at 220 and would just hold there in stop and go traffic. i'm going to drain the coolant and replace the t-stat tomorrow morning and if that doesn't fix it i'll pick up a new sender.
Old Jul 5, 2010 | 05:49 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
He could be right.
My IROC had a canadian gauge cluster in it from the factory and the temp is in *C.
Old Jul 5, 2010 | 05:51 PM
Twin_Turbo's Avatar
Did you remove that cluster? Do you still have it?
Old Jul 5, 2010 | 06:03 PM
Yes, see here:
https://www.thirdgen.org/forums/conv...ml#post4600602
Yes, I do.
Old Jul 6, 2010 | 12:49 AM
Car: 2001 Camaro SS
Originally Posted by bradley23150
He could be right.
nope mine is the US version
Old Jul 6, 2010 | 08:21 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I had that happen once when my thermostat stuck open. Drove it for 45 minutes to class and it never went above 100. Idling around the parking lot got it up to 160.
Old Jul 6, 2010 | 10:15 AM
Car: 2001 Camaro SS
well in a little bit i'm going to jack her up and drain it out . . . i'm keeping my fingers crossed i don't find a reason it's sticking
Old Jul 6, 2010 | 02:34 PM
Car: 2001 Camaro SS
temp gauge works now! but didn't drive it around long enough to let the temp get up to 200 and see if the fan turns on
Old Jul 6, 2010 | 04:20 PM
Car: 1992 RS
Engine: Carbed 350
Old Jul 6, 2010 | 04:28 PM
Car: 2001 Camaro SS
nevermind lol
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
