radiator hoses --really hard ,,normal
Old Jul 6, 2010 | 06:57 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i have just a question regarding rad hoses,,,when the car starts and runs even for a few minutes the rad hoses especially the top one becomes hard like a rock...it doesn't overheat because my temp gauge says barely 1/4 ,,it has a new temp switch and a 6 blade flex fan that runs all the time bolted to the pulley at the same speed as the engine,,,has a 160 degree thermostat...runs fine ,,,but the hoses are hard,,,is this normal?...it has been like that for years....it's a 350 1985 camaro with mild mods including cam....thanks.
Old Jul 6, 2010 | 07:38 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: radiator hoses --really hard ,,normal
Yes thats normal, that means the cooling system is building pressure. And the only reason the cooling system builds pressure is to raise the boiling point of the coolant so that the engine wont overheat. Dont worry about it.
Old Jul 6, 2010 | 08:50 PM
mooch1's Avatar
Transmission: T5 WC
ok...thanks...
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
Randomtask2
Sep 7, 2015 05:06 PM
Glowsock
Sep 6, 2015 06:40 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
